1 minute ago, LukeTheCoder05 said:
I think another company did this (Origin, MSI, etc) But try building a backpack VR pc. Just a PC on your back so of your cables is just power.
I think that was Zotac that did that too.
I like this idea, but imagine if it wasn't just for VR. A pc built completely inside a backpack. You could hook up a portable monitor with it and use it for hours just off of a battery built into the backpack...this would be sick.
I got a ps5 and a pc pretty ballin
https://linustechtips.com/topic/1068101-system-designs/#findComment-12606220
Yeah, Have this bar that folds down in front of you with your display and keyboard.
Not sure about you but I think my 7 year old CPU still rips
https://linustechtips.com/topic/1068101-system-designs/#findComment-12606223
Exactly! That would be sweet!
Edit: can you imagine what an idiot you would look like if you actually had that tho??? ?
https://linustechtips.com/topic/1068101-system-designs/#findComment-12606227
Have you seen the LTT camera gear???
https://linustechtips.com/topic/1068101-system-designs/#findComment-12606249
  • 3 months later...
55 minutes ago, Blue4130 said:
What those guys were describing, a computer in a backpack, with a battery and a portable screen... It exists. It's called a laptop.
Nope. A full desktop experience built into a backpack. That way there isn’t cooling (and therefore throttling) issues that many powerful laptops have.
https://linustechtips.com/topic/1068101-system-designs/#findComment-12915733
Right, because even more powerful hardware in a not much bigger space would work better.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/1068101-system-designs/#findComment-12916488
