CPU Overheating at Idle - Out of Ideas
dt_
Short:
Problem: My CPU gets way to hot. This happens even at idle. Cannot figure out why. I have tried a lot of things with no luck. I fear the end.
Long:
I have been running an intel i7-3930k paired with a corsair H100i aio since the year that the 3930k was released. The chip still runs outstanding for its age (until now). For at least half of the chip's life it has ran a modest overclock. It ran at 4.0Ghz stable for over 4 years without any issues. Temps at a max would hit 80C under 100% load. This type of load was rare, as I rarely did any encoding/rendering/etc. Mostly just games and servers.
The CPU started acting up a few days ago when it started to take a few minutes to boot up. It would then prompt windows to log off and shutdown right after startup for no known reason. This is when I found out my CPU temps would reach over 90C just from startup. It will get just as hot in the BIOS. If windows takes too long to boot up the pc will tjmax and cut power instantly. This obviously leaves the pc as useless. The issue is clearly the heat from the CPU, I just cannot narrow down why.
I have been building computers for around 8 years now and have yet to have a CPU go bad on me. I have ran out of idea's to try and fix this problem. It may be the case that the CPU is actually done. I have tried many different methods to get the heat down but had no luck.
**Room temp: 72deg F.
**CPU overheats at idle.
Things I have tried:
- Started by clearing cmos to factory settings to set my cpu and ram to stock speeds.
- Unmounted the H100i and applied a new quality thermal paste (Arctic Silver or something like that).
- Re-seated the CPU.
- Ensured all fans and airflow are working and optimal.
- Ensured the pump on the H100i is actually pumping.
- Changed the liquid in the H100i (The old liquid had mold in the loop when I drained it. I was concerned that the mold might be clogging the loop, but you can feel the flow through the rubber tubes). **You can feel the liquid get hot in the tube when the system is running.
- Cleaned the mold out of the cooling fins inside the head of the H100i. (The backside of the copper contact with the IHS).
- Undervolting the CPU in the bios. - Temps ran the same at 90C until shutdown and was surprised that windows would launch by taking .15v away from stock voltage. (Stock: aorund 1.25v... undervolted to: 1.1v) When this didn't work I reset this back to stock.
- Disconnecting extra BS that is not essential to the machine running.
- Ensured that dust is not an issue (In case/fans/radiator/etc.)
- Ensured that the BIOS is up to date (Not that this should matter as it is running the same version that the pc ran fine on for years).
- I am sure I have tried more, this is all I can think off the top of my head..
* When I let the CPU cool down to room temperature then start running the system. It takes less than 1 minute for the CPU to reach 90C in the bios before I pull the plug.
* Delidding is not an option as I believe the i7-3930k is soldered.
* Everything works the way it should. Windows and Linux will boot and run. All devices work. The temps (and consequently system shutdowns) are the only problem.
* No error codes
* Temps on GPU / HDD / SSD are fine.
Anyone have any ideas? Or is the chip doomed?
I appreciate your time.
Full Specs:
intel i7-3930k
Corsair H100i AIO
16gb ddr3 g.skill ripjaws xmp
EVGA X79 classified motherboard
Asus GTX1080 strix
Samsung SSD 850 evo
EVGA Supernova P2 1000W 80+ plat
A huge case. Rosewill thor or something.
Windows 10 x64
Manjaro Linux
To me this does still sound like an issue with your H100i.
Do you have another cooler to try?
There's a time and place for everything! But not now. - Professor Oak
i7 2600K 4.3GHz  -  GTX 1060 3GB  - ASUS P8Z68-V - 16GB DDR3-1600 CL9 - EIZO 1080p 120Hz VA
Intel Skulltrail: 2x Core 2 Quad QX9775 - Intel D5400XS - 16GB FB DDR2-800 CL5 Quad Channel
EVGA SR-2 Classified - 2x Xeon X5675 4.2GHz - 24GB DDR3-1830 C10 Triple Channel
Intel Skulltrail #2: 2x Xeon E5472  - Intel D5400XS - 16GB FB DDR2-667 CL5 Quad Channel
Unfortunately I do not have one that fits this socket.
That is why I have gone to such lengths of making sure the H100i is working properly.
I pulled the CPU out of the motherboard and ran power to just H100i unattached so that I could feel the copper block itself as it ran and certainly feels as if the aio is doing its job.
sounds like a dead AIO to me.
get a good Aircooler instead.
How old is the H100i? AIO-s have a life-span of about 3 years.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 30+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - HyperX Alloy Origins Core (TKL) - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Arcadyan ISP router - 35/5 Mbps vDSL
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
This AIO is old. As old as the CPU coming in around 6-7 years old.
Most AIO's die as a result of the pump failing, or in rare instances the liquid evaporating off.
Although old, this H100i definitely has a working pump and I changed the liquid just a day ago.
When the system is running you can feel the liquid pumping through the tubes and you can feel the tubes getting warm as a result of the CPU heat being pumped around.
Agree with this. Probably a dead pump
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
or clogged fins in the radiator or many other reasons.
The CPU can overheat in under 1 minute. Surely that is not near enough time for clogged fins / restricted flow to play an issue. I can say with 100% confidence that the pump is functional. I can also say with 100% confidence that liquid is flowing.
that is enough time for it to overheat.
have you tried just having a metal cup filled with water, thermal paste it to the CPU and check temps?
that is one way of checking. because its most likely a dead AIO
Interesting, I will look for a metal cup and give it a try. Thanks for the suggestion. Ill report with my findings
20190529_043011.thumb.jpg.68b666b3fa2d64dc75062c9ee3000843.jpg20190529_043101.thumb.jpg.c5398ff41297a98edafb2a82c0c85f9a.jpg
Metal cup with thermal paste. Added iced water so it was very cold. Still hits 90C.
I believe the AIO is fine
That’s the same temp as with aio correct? Sounds to me your pump is dead. (As it is 8 years old, and sometimes after 4-5 years aio’s can fail.
It is the same temp, however it was a cup of iced water. The cup was still very cold by the time the CPU was hitting max temp. I believe the problem is with the chip as this would be way colder than any cooling solution outside of liquid nitrogen.
  • 1 year later...
2 years later, did you find the problem ?
I seem to have the same problem.  Voltage issue ? mother board prob ?  etc.  ?
  • 8 months later...
Did you find the culprit as to why your cpu is overheating? Because I too is having the same problem even though my pc is only 9 months old.
I'll try getting an aircooler and look see if it changed.
