Posted May 25, 2019 I have a MSI mortar titanium motherboard i plan to put it in a full atx case will it be ugly or is it a good idea?(Want full atx case for better airflow for gpu) Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 25, 2019 depends... If you have a whole bunch of stuff (HDDs for example) to cover up the empty space below the board, then sure it will look fine. Why not mid tower ATX? CPU: i7-2600K 4751MHz 1.44V (software) --> 1.47V at the back of the socket Motherboard: Asrock Z77 Extreme4 (BCLK: 103.3MHz) CPU Cooler: Noctua NH-D15 RAM: Adata XPG 2x8GB DDR3 (XMP: 2133MHz 10-11-11-30 CR2, custom: 2203MHz 10-11-10-26 CR1 tRFC:230 tREFI:14000) GPU: Asus GTX 1070 Dual (Super Jetstream vbios, +70(2025-2088MHz)/+400(8.8Gbps)) SSD: Samsung 840 Pro 256GB (main boot drive), Transcend SSD370 128GB PSU: Seasonic X-660 80+ Gold Case: Antec P110 Silent, 5 intakes 1 exhaust Monitor: AOC G2460PF 1080p 144Hz (150Hz max w/ DP, 121Hz max w/ HDMI) TN panel Keyboard: Logitech G610 Orion (Cherry MX Blue) with SteelSeries Apex M260 keycaps Mouse: BenQ Zowie FK1 Model: HP Omen 17 17-an110ca CPU: i7-8750H (0.125V core & cache, 50mV SA undervolt) GPU: GTX 1060 6GB Mobile (+80/+450, 1650MHz~1750MHz 0.78V~0.85V) RAM: 8+8GB DDR4-2400 18-17-17-39 2T Storage: HP EX920 1TB PCIe x4 M.2 SSD + Crucial MX500 1TB 2.5" SATA SSD, 128GB Toshiba PCIe x2 M.2 SSD (KBG30ZMV128G) gone cooking externally, 1TB Seagate 7200RPM 2.5" HDD (ST1000LM049-2GH172) left outside Monitor: 1080p 126Hz IPS G-sync Desktop benching: Cinebench R15 Single thread:168 Multi-thread: 833 SuperPi (v1.5 from Techpowerup, PI value output) 16K: 0.100s 1M: 8.255s 32M: 7m 45.93s Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 25, 2019 That's really for you to decide. It's completely subjective. Here's what an MATX board looks like in an ATX case, in case you want a reference Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 25, 2019 Author 6 minutes ago, Jurrunio said: depends... If you have a whole bunch of stuff (HDDs for example) to cover up the empty space below the board, then sure it will look fine. Why not mid tower ATX? I just have 2 ssd i was planning to get the NZXT H500 WHITE Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 25, 2019 4 minutes ago, M0SIE said: I just have 2 ssd i was planning to het the NZXT H500 WHITE then whatever, it's up to you. The hardware doesn't care, that's for sure. 10 minutes ago, M0SIE said: (Want full atx case for better airflow for gpu) NZXT H500's thermals isn't good, not recommended for people who care more than just "no thermal throttling" CPU: i7-2600K 4751MHz 1.44V (software) --> 1.47V at the back of the socket Motherboard: Asrock Z77 Extreme4 (BCLK: 103.3MHz) CPU Cooler: Noctua NH-D15 RAM: Adata XPG 2x8GB DDR3 (XMP: 2133MHz 10-11-11-30 CR2, custom: 2203MHz 10-11-10-26 CR1 tRFC:230 tREFI:14000) GPU: Asus GTX 1070 Dual (Super Jetstream vbios, +70(2025-2088MHz)/+400(8.8Gbps)) SSD: Samsung 840 Pro 256GB (main boot drive), Transcend SSD370 128GB PSU: Seasonic X-660 80+ Gold Case: Antec P110 Silent, 5 intakes 1 exhaust Monitor: AOC G2460PF 1080p 144Hz (150Hz max w/ DP, 121Hz max w/ HDMI) TN panel Keyboard: Logitech G610 Orion (Cherry MX Blue) with SteelSeries Apex M260 keycaps Mouse: BenQ Zowie FK1 Model: HP Omen 17 17-an110ca CPU: i7-8750H (0.125V core & cache, 50mV SA undervolt) GPU: GTX 1060 6GB Mobile (+80/+450, 1650MHz~1750MHz 0.78V~0.85V) RAM: 8+8GB DDR4-2400 18-17-17-39 2T Storage: HP EX920 1TB PCIe x4 M.2 SSD + Crucial MX500 1TB 2.5" SATA SSD, 128GB Toshiba PCIe x2 M.2 SSD (KBG30ZMV128G) gone cooking externally, 1TB Seagate 7200RPM 2.5" HDD (ST1000LM049-2GH172) left outside Monitor: 1080p 126Hz IPS G-sync Desktop benching: Cinebench R15 Single thread:168 Multi-thread: 833 SuperPi (v1.5 from Techpowerup, PI value output) 16K: 0.100s 1M: 8.255s 32M: 7m 45.93s Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 25, 2019 Or get a bigger mATX case like the Cooler Master Case Pro 3? Personal Desktop": CPU: Intel Core i7 10700K @5ghz |~| Cooling: bq! Dark Rock Pro 4 |~| MOBO: Gigabyte Z490UD ATX|~| RAM: 16gb DDR4 3333mhzCL16 G.Skill Trident Z |~| GPU: RX 6900XT Sapphire Nitro+ |~| PSU: Corsair TX650M 80Plus Gold |~| Boot: SSD WD Green M.2 2280 240GB |~| Storage: 1x3TB HDD 7200rpm Seagate Barracuda + SanDisk Ultra 3D 1TB |~| Case: Fractal Design Meshify C Mini |~| Display: Toshiba UL7A 4K/60hz |~| OS: Windows 10 Pro. Luna, the temporary Desktop: CPU: AMD R9 7950XT |~| Cooling: bq! Dark Rock 4 Pro |~| MOBO: Gigabyte Aorus Master |~| RAM: 32G Kingston HyperX |~| GPU: AMD Radeon RX 7900XTX (Reference) |~| PSU: Corsair HX1000 80+ Platinum |~| Windows Boot Drive: 2x 512GB (1TB total) Plextor SATA SSD (RAID0 volume) |~| Linux Boot Drive: 500GB Kingston A2000 |~| Storage: 4TB WD Black HDD |~| Case: Cooler Master Silencio S600 |~| Display 1 (leftmost): Eizo (unknown model) 1920x1080 IPS @ 60Hz|~| Display 2 (center): BenQ ZOWIE XL2540 1920x1080 TN @ 240Hz |~| Display 3 (rightmost): Wacom Cintiq Pro 24 3840x2160 IPS @ 60Hz 10-bit |~| OS: Windows 10 Pro (games / art) + Linux (distro: NixOS; programming and daily driver) Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 25, 2019 Author 1 minute ago, Princess Luna said: Or get a bigger mATX case like the Cooler Master Case Pro 3? What about a Corsair Carbide Series 275R Mid-Tower Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 25, 2019 I want to put two mini-ITX boards inside a 1000D. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
