I just built a brand new computer with a 1660 ti and ryzen 5. Before installing windows in any way, should I still get a bios screen or anything? When I turn on the computer everything seems fine, the fans run and the computer does not restart. Nothing shows up on the screen except no signal even though the hdmi is connected properly.
https://linustechtips.com/topic/1066655-help-please/
Is the video cable plugged into the GPU or the motherboard video port?  Also what video cable and are the cable and monitor known-working?
https://linustechtips.com/topic/1066655-help-please/#findComment-12593272
1 minute ago, Faisal A said:
You should get an american megatrend sign
Since you don't know his motherboard and you didn't hedge you guess against all known Ryzen motherboards that's not really accurate.  It wouldn't say that in specific if he has a BIOS from any vendor that displays an image instead (Many OEM hide that image and show something else until it fails to boot an OS), or another BIOS maker like Phoenix, etc (there is more than 1 yah know).
https://linustechtips.com/topic/1066655-help-please/#findComment-12593281
That’s not true...
I’ve never had that.
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
https://linustechtips.com/topic/1066655-help-please/#findComment-12593297
Just now, Faisal A said:
@Stormseeker9 most mobos show an american megatrend screen if there is no hard drive or operating system installed
Oh mine did not. I installed everything, turned on for the first time and it went into bios straight away.
I have Wondered tho, I sometimes see people’s pc boot (all installed etc) and they still get that splash screen. always wondered why I never had it
https://linustechtips.com/topic/1066655-help-please/#findComment-12593308
2 minutes ago, Faisal A said:
@Stormseeker9One of my PCs just shows the company logo. Probably a diffrent BIOS
Yeah I have the MSI splash screen before it goes into w10
https://linustechtips.com/topic/1066655-help-please/#findComment-12593319
23 minutes ago, Faisal A said:
Is the GPU in the PCIe slot securely ? Try pushing it and then see if you get a signal
Turn it off first... lol.
https://linustechtips.com/topic/1066655-help-please/#findComment-12593346
