Could you explain a little better? This makes no sense in the way it is written.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1066584-gpu-rpm-load-on-cpu/#findComment-12592552
wat. CPUs doesnt have an "RPM" nor a redline or oil or coolant.
https://linustechtips.com/topic/1066584-gpu-rpm-load-on-cpu/#findComment-12592553
CPU load will naturally increase if you install more powerful GPU. 2080 ti requires a lot more data from the CPU because its extremely fast. There is nothing to worry about unless your CPU is overheating or reaching 100% load.
Main system: Ryzen 7 7800X3D / Asus TUF Gaming B650-Plus / G.Skill Trident Z5 NEO 32GB 6000Mhz / Zotac RTX 5090 SOLID OC/ x2 WD_BLACK NS770 2TBs/ Corsair HX1000i/ NZXT H5 Flow
https://linustechtips.com/topic/1066584-gpu-rpm-load-on-cpu/#findComment-12592555
Dear Skiiwee29,
First of all thnx for taking interest in my section,
Secondly I m saying tht due to  dual graphics card rpm (fan curve) , my cpu  take more load then before.
https://linustechtips.com/topic/1066584-gpu-rpm-load-on-cpu/#findComment-12592976
Dear Levent,
 I’m lil bit worry about tht .
https://linustechtips.com/topic/1066584-gpu-rpm-load-on-cpu/#findComment-12592982
6 hours ago, Ayush007 said:
Dear Skiiwee29,
The fan Speed of your Graphics Card should have zero impact on the performance of your CPU.
Community Standards
"Beast Mode"
https://linustechtips.com/topic/1066584-gpu-rpm-load-on-cpu/#findComment-12593702
Ohhk , thnx for your co-operation
bdw previously I broke the usb 3.0 reader pin in motherboard while cleaning , so this may be the cause of concern.
https://linustechtips.com/topic/1066584-gpu-rpm-load-on-cpu/#findComment-12594279
