I've been having an issue since I built my PC back in March where, in most titles, my CPU and GPU usage percentages are low, resulting in low FPS. Changing graphical settings in the games where this occurs gives no difference in performance. Temperatures across the board are fine, and neither the GPU nor the CPU are overclocked. In benchmarking applications (Cinebench, 3DMark, Heaven), I see expected usage and performance.
What I've tried so far:
Reinstalling GPU drivers AND rolling back to older versions
Reinstalling Chipset drivers
Uninstalling GeForce Experience
Setting Windows Power Plan to both Ryzen Balanced and High Performance
Setting PCI Express Link Power Management to Off in the advanced power settings
Changing all settings in NVIDIA Control Panel to prefer Maximum Performance
Clearing CMOS
Disabling HPET and Virtualization
Disabling Hyper-threading
Reinstalling OS
Specs for the build:
Windows 10 Pro 64-bit
AMD Ryzen 5 2600
EVGA RTX 2070
MSI B450 Tomahawk Motherboard
G.Skill Aegis 2x8GB 2400Mhz RAM
EVGA Supernova 80+ Gold 750W PSU
I've posted on numerous forum sites and no one has been able to give me a definitive answer so far, so any help towards finding a solution would be very much appreciated!
Down below are HWInfo Logs.
Borderlands 2.CSV
CSGO Match.CSV
Destiny 2 Patrol.CSV
GTA 5 Benchmark.CSV
GTA 5 Online.CSV
Overwatch Match.CSV
https://linustechtips.com/topic/1066373-low-cpu-and-gpu-usage/
Something to point out regarding CPU usage: unless the game provides enough threads on average to be run on the CPU to saturate it, it's never going to show as 100% or anywhere close. And it may not even show a single logical processor on Task Manager as 100%.
In your case with the Ryzen 2600, unless you have a game that has 12 threads ready to run all the time, it's never going to be at 100%. Since you mentioned GTAV, PCPer did an article some time ago where they profiled the game with regards to how many threads it has ready to run on average:
If we consider 5 threads to be about where GTA V sits most of the time, then one can expect that on average, the Ryzen 2600 won't be over 50% utilization.
Unfortunately yes, this isn't going to help solve your problem, but what I'm arguing here is low CPU utilization may be a red herring.
https://linustechtips.com/topic/1066373-low-cpu-and-gpu-usage/#findComment-12590511
14 minutes ago, FeelingLikeTimmy said:
Snip
Could well be the ram speed, seen it before (once) that low specced ram causing these kind of problems.
Ryzen loves +3000mhz ram, but not sure how GPU is also low.
what resolution do you game on?
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
https://linustechtips.com/topic/1066373-low-cpu-and-gpu-usage/#findComment-12590514
1080p
https://linustechtips.com/topic/1066373-low-cpu-and-gpu-usage/#findComment-12590528
11 minutes ago, Sorenson said:
Older games typically put most of the burden on one cpu core. If i'm reading your report right, one core is up in the 80-90% utilization which is acting as the bottleneck.
That must be from when one of the games was loading. When I was looking at the logs in the HWInfo Log Viewer, none of the threads were ever consistently peaking that high.
https://linustechtips.com/topic/1066373-low-cpu-and-gpu-usage/#findComment-12590596
maybe, try using MSI afterburner. Load up the game, put it in windowed mode, and scroll through the usage reports. In my opinion it is a lot easier to read than HWinfo.
https://linustechtips.com/topic/1066373-low-cpu-and-gpu-usage/#findComment-12590600
