PCPartPicker Part List
Type Item Price
CPU Intel - Core i9-9900K 3.6 GHz 8-Core Processor £451.98 @ Aria PC
CPU Cooler be quiet! - Dark Rock Pro 4 50.5 CFM CPU Cooler £67.25 @ CCL Computers
Motherboard Asus - PRIME Z370-A II ATX LGA1151 Motherboard £142.99 @ AWD-IT
Memory Corsair - Vengeance LPX 16 GB (2 x 8 GB) DDR4-2400 Memory £67.98 @ Aria PC
Storage Kingston - HyperX Fury 240 GB 2.5" Solid State Drive £87.80 @ Amazon UK
Storage Samsung - 850 EVO-Series 250 GB 2.5" Solid State Drive £79.99 @ Amazon UK
Storage Samsung - 970 Evo 1 TB M.2-2280 Solid State Drive £199.99 @ Box Limited
Storage Western Digital - BLACK SERIES 1 TB 3.5" 7200RPM Internal Hard Drive £68.29 @ Amazon UK
Video Card EVGA - GeForce GTX 1080 8 GB FTW Gaming ACX 3.0 Video Card £545.47 @ Scan.co.uk
Case NZXT - H440 ATX Mid Tower Case
Power Supply Corsair - RMx (2018) 750 W 80+ Gold Certified Fully Modular ATX Power Supply £115.40 @ Alza
Operating System Microsoft - Windows 10 Home OEM 64-bit £83.99 @ Amazon UK
Software Microsoft - Office Professional 2016 Software £14.90 @ Amazon UK
Wireless Network Adapter TP-Link - TL-WDN4800 PCIe x1 802.11a/b/g/n Wi-Fi Adapter
Monitor BenQ - XL2430T 24.0" 1920x1080 144 Hz Monitor
Keyboard Corsair - K70 RGB MK.2 Wired Gaming Keyboard £102.11 @ Amazon UK
Mouse Logitech - G502 HERO Wired Optical Mouse £73.69 @ Overclockers.co.uk
Headphones SteelSeries - Arctis 5 7.1 Channel Headset £77.98 @ PC World Business
  Prices include shipping, taxes, rebates, and discounts
  Total £2179.81
  Generated by PCPartPicker 2019-05-23 11:34 BST+0100
So this is my PC build, I already have basically everything this is just what I'm using to show what I have. I'm just curious as to if I should upgrade my RAM as compared to the rest of my PC it's a bit weak. So I was thinking maybe I should just get rid, and maybe get some faster RAM, and maybe 2x16 instead? Or is there not much point?
Thanks!
Current PC
CPUIntel Core i9 9900k
GPUGTX 1080 8GB FTW EVGA
MotherboardASUS PRIME Z370-A II
RAM: Corsair Vengeance LPX (2x8GB) DDR4 2400 Mhz
Storage 1: Samsung 850 EVO 250GB
Storage 2: Hyper X 240GB
PSU: Corsair RM750 80 Plus Gold 750W
Peripherals: Logitech G502 Hero//Corsair K70 MK 2 Cherry MX Red
Display: BenQ XL2430T 24-inch 144Hz
https://linustechtips.com/topic/1066279-ram-maybe-help/
For intel, RAM speed doesnt make nearly as much sense or difference compared to Ryzen. Unless you can find a really good deal on 3000 or 3200 speed kit, I wouldnt change it if you already have it. 16gb is all you need for gaming and everyday use.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1066279-ram-maybe-help/#findComment-12589572
4 minutes ago, _d0nut said:
Use case? Are you only going to be gaming on this? You can get a 2070 for cheaper than the 1080, since 10 series cards are not being produced, they are very expensive.
For gaming, 2x8gb is sufficient and an NVME SSD is not needed
I was just using PC part picker as a way of showing what I have, I already have all of the parts, I was just curious about the RAM is all, thanks for your help though :)
Current PC
https://linustechtips.com/topic/1066279-ram-maybe-help/#findComment-12589575
Thanks again! :D
Current PC
https://linustechtips.com/topic/1066279-ram-maybe-help/#findComment-12589578
1 minute ago, Ardu said:
Thanks again! :D
np, and if you want to try and have fun, you can likely overclock the RAM to higher speeds as well manually.
Community Standards
"Beast Mode"
https://linustechtips.com/topic/1066279-ram-maybe-help/#findComment-12589584
I'll look into it when I'm all set up :)
Current PC
https://linustechtips.com/topic/1066279-ram-maybe-help/#findComment-12589592
Yeah I don't plan to OC the CPU tbh. Mainly because like, it will just be overkill really, not really any need for it to be faster for gaming.
Current PC
https://linustechtips.com/topic/1066279-ram-maybe-help/#findComment-12589642
I noticed you put a WD Black 1TB hard drive in your list. The 1TB WD Black hard drives aren't worth the money and if you're buying 1TB, I recommend you use the WD Blue instead as it offers similar performance for a cheaper price. The WD Black offers better reliability due to features such as anti-vibration pads, etc., however, only from the 2TB model. Also, WD Black hard drives are much louder than WD Blue hard drives.
Edit: I also noticed you have a 970 Evo in your list. The 970 Evo Plus costs roughly the same as the 970 Evo and offers more performance. Also, why a 1TB NVMe SSD and 2 small, 240GB SATA SSDs, from different vendors? Make sure you really are going to use the speed of an NVMe SSD before spending that much on one and if you really need that much SSD storage, just go with one 500GB SSD instead of two 240GB SSDs.
Quote me so I can reply back :)
MY PC-> PSU: EVGA SuperNOVA T2 1000W 80 Plus Titanium MOTHERBOARD: ASUS X370 Crosshair VI Hero CPU: RYZEN 7 3700X RAM: G.Skill 32GB (4X8GB) DDR4 3200MHz C14 GPU: EVGA GTX 1080Ti FTW3 HYBRID STORAGE: Samsung 970 EVO 500GB NVMe SSD; 2TB WD Caviar Blue; Crucial MX500 500GB SSD CUSTOM LOOP: EK-Velocity Nickel + Plexi CPU block, EK-FC1080 GTX Ti Acetal + Nickel GPU Block w/ EK-FC1080 GTX Ti Backplate, EK-XRES 140 Revo D5 PWM, EK-CoolStream PE 240 w/ 2x Noctua NF-F12 Chromax fans, EK-ACF Fitting 10/13mm Nickel, Mayhems UV White tubing 13/10mm, 3x Noctua NF-S12A Chromax case fans
https://linustechtips.com/topic/1066279-ram-maybe-help/#findComment-12589683
NVME speeds will only really show their speed when moving big files and during bootup. Booting to windows is like 5 seconds faster on NVME too. Gaming won't see any difference between NVME and SATA SSDs, so it might be wiser to go for 1-2 1TB SATA SSDs(860 Evo maybe?)
https://linustechtips.com/topic/1066279-ram-maybe-help/#findComment-12589750
I appreciate what your saying, but this is my current PC, I was just suing PCPP as like a way to list what I have, I've had some of these parts for years, so like the WD Black is like 4 years old, and the SSD's are 2 and 1 year old, that's why it looks so odd, sorry for the confusion.
Current PC
https://linustechtips.com/topic/1066279-ram-maybe-help/#findComment-12589833
Never mind. If only I had read the whole post, I would read the part where you say that is your current setup. Sorry for the confusion.
https://linustechtips.com/topic/1066279-ram-maybe-help/#findComment-12589844
No problem fella :)
Current PC
https://linustechtips.com/topic/1066279-ram-maybe-help/#findComment-12589849
There is a performance difference but it is quite small, see https://www.techpowerup.com/reviews/Intel/Core_i7_8700K_Coffee_Lake_Memory_Performance_Benchmark_Analysis/ for data.
Going to 32GB would offer some improvement. In the general case, more memory offers a better performance improvement than higher speed memory. Unless one is into content creation or other memory intensive work, the real world benefit of 32GB over 16GB would be marginal.
https://linustechtips.com/topic/1066279-ram-maybe-help/#findComment-12590244
