High Ryzen 5 1600 idle temperature?
Solved by PopsicleHustler,
Just now, Draconid said:Okay, I'll try and reduce the voltage, thanks for the pointer; will the voltage have an effect on temperature? I'm pretty certain it would.
Yes it will. Voltage is the reason why temps go up in overclock.
Featured Topics
1
2
Joseph_Stalin ·
Posted in General Discussion4 -
Evan37 ·
Posted in New Builds and Planning5 -
IlanMS ·
Posted in Peripherals9 -
Frossty ·
Posted in Graphics Cards9 -
StephenB95 ·
Posted in Displays4 -
5
