cheapest, smallest, MICRO ATX and red and black themed pc case?
_Elon_
what is the cheapest, smallest, MICRO ATX and red and black themed pc case? under AUD$70
smol case
It sounds like you want a window. You can get the h200i in red and black. However, it isn’t really SFF size. If you want super small, and not a piece of crap, with a window I would go with the n-case m1
thanks, but it aint micro atx.
mini itx mobo's are waaay more expensive the micro atx mobo's
My bad, I was thinking itx, with micro atx I would go with something like the nzxt h400.
Just now, Sorenson said:
My bad, I was thinking itx, with micro arc I would go with something like the nzxt h400.
and that's too expensive lol (AUD)
If you can't find one, don't bother
Or you could not be lazy and google your self ?
i tried, and its hard
This may help, it's a PCPP list for Micro ATX Mini Tower cases in Australia under $70.
https://au.pcpartpicker.com/products/case/#f=7&X=0,7112&sort=price&t=6
Maybe the Thermaltake Versa H18 or the Cooler Master Q300L?
I wouldn't be too worried about the colour scheme when searching for a case. It's very easy to change the look of a case with some RGB (or just some cheap plain red LED) fans. Even just a bit of red paint around the edges could give it enough of a red accent.
smol case
Corsair SPEC M2 fits the bill.  It has been discontinued, but you might find one floating around at a retailer in your area.  Air240 would be a great choice as well if you can increase your budget a little bit or find a deal on one.
Looking for more details about a product, or experiencing technical issues?  Visit our support page below, and one of our Technical Support staff can help you out:
https://support.corsair.com/
