So basically, whenever I plug in my microphone, it doesn't turn on and says "Power surge on the USB port. Unknown USB Device needs more power than the port can supply". This is the first time it has happened but I have had the mic for months. If you need to know, it is a Blue Yeti Mic, here's the link to it on Amazon. https://www.amazon.com/Blue-Yeti-USB-Microphone-Blackout/dp/B00N1YPXW2/ref=sr_1_3?gclid=Cj0KCQjwzunmBRDsARIsAGrt4mtjEfigSRY9I3NUlHNW959Kd_s_5bfDiyYgpxjd5vxa1uZz9aqM73caAg1kEALw_wcB&hvadid=177218034405&hvdev=c&hvlocphy=9014901&hvnetw=g&hvpos=1t1&hvqmt=e&hvrand=17775906225930123621&hvtargid=kwd-14664349409&hydadcr=18911_9698412&keywords=blue+yeti+microphone&qid=1557865395&s=gateway&sr=8-3
https://linustechtips.com/topic/1063871-usb-not-working/
  • 1 year later...
Plug it into a USB port coming off a different USB controller....
Sloth's the name, audio gear is the game
I'll do my best to lend a hand to anyone with audio questions, studio gear and value for money are my primary focus.
Click here for my Microphone and Interface guide, tips and recommendations
For advice I rely on The Brains Trust :
@rice guru
- Headphones, Earphones and personal audio for any budget
@Derkoli- High end specialist and allround knowledgeable bloke
https://linustechtips.com/topic/1063871-usb-not-working/#findComment-14421964
If its a laptop it may have to do with the laptop being plugged in.
If its a computer it, if its a front pannel USB the power shared between the ports may mean its not enough try using another USB port on the back. Also avoid using USB splitters as that splits the power so it wouldnt be getting enough.
https://linustechtips.com/topic/1063871-usb-not-working/#findComment-14423148
