Um, js help :DD pls
Go to solution Solved by mariushm,
Well, this would work:
<html>
<body>
<script type="text/javascript">
var toggled = false;
        function toggle() {
        if(!toggled) {
        toggled = true;
        let d = new Date(Date.now());
        document.getElementById("tgl").innerHTML = d.getHours() + ':' + d.getMinutes() + ':' + d.getSeconds();
        return;
        if(toggled) {
        toggled = false;
        document.getElementById("tgl").style.display = "block";
        return;
</script>
<div id="tgl">text</div>
<input name="go" type="submit" onclick="toggle();"; />
</body>
</html>
So, i want to make a function "clock"! It's a button and onclick i would display my function, but as i am newbie on js i really need your help :)
i've got this:
Quote
var toggled = false
        function toggle() {
        if(!toggled) {
        toggled = true;
        var  d = new Date();
        var  n = d.getHour();
        document.getElementById("tgl").innerHTML = n;
        return;
        if(toggled) {
        toggled = false;
        return;
How do i make that  button display the hour?
https://linustechtips.com/topic/1063858-um-js-help-dd-pls/
<html>
<body>
        function toggle() {
        if(!toggled) {
        toggled = true;
        return;
        if(toggled) {
        toggled = false;
        return;
</script>
</body>
</html>
https://linustechtips.com/topic/1063858-um-js-help-dd-pls/#findComment-12567023
<html>
<body>
        function toggle() {
        if(!toggled) {
        toggled = true;
        return;
        if(toggled) {
        toggled = false;
        return;
</script>
</body>
</html>
Yeah, it does work, but now the button only has one function onclick = show time, i wanted to make this a toggle button, so... i need to somehow to "turn it off"
https://linustechtips.com/topic/1063858-um-js-help-dd-pls/#findComment-12567038
The button just calls the function. It's there just to make it easy for you to see the function being executed.
Your problem was that you couldn't display text in the div, now it does.
It's up to you to fix everything else, like get the function to be executed every half a second or every second to have the time updated
https://linustechtips.com/topic/1063858-um-js-help-dd-pls/#findComment-12567044
:/ Sad thing is, i don't know how to, but still thanks :)
https://linustechtips.com/topic/1063858-um-js-help-dd-pls/#findComment-12567045
<html>
<body>
		function updateTime() {
        return;
		window.setInterval(updateTime,500);
</script>
</body>
</html>
https://linustechtips.com/topic/1063858-um-js-help-dd-pls/#findComment-12567063
