Hey guys!
Im a little new to the whole computer world. Im trying to help my friend bargain and tweak this computer. Please help!
1) I need some pricing on this computer
2) I need some opinions on what should be upgraded ASAP
3) I need a budget 60 hertz monitor thats affordable for a teenage kid.
4) Would powerline ethernet be a good option?
https://linustechtips.com/topic/1063648-i-need-help/
13 minutes ago, Squanchy said:
Well being as the processor alone is 10 years old. And the GPU itself can be bought used for about 80 bucks on ebay. I wouldn't spend anymore then 250-ish bucks. (That's me tho)
How much did they post it for?
400$. Yeah thats an old processor. I also kind of found it suspicious he uses two different brands of ram? Give me a quote so i can bargain this guy down?
https://linustechtips.com/topic/1063648-i-need-help/#findComment-12564624
i5 750 = $20 (eBay)
Motherboard = $50 (maybe, idk what board it is, just guessing)
120GB Kingston SSD = $10 (it's only $20 brand new)
Used 1TB HDD = $10
RD 380 = $80 (eBay)
Case = $30
PSU = Worthless
So yeah, $200ish.
Nothing suspicious about using different brands of RAM. They probably had 4GB when they built the system 10 years ago and then at some point added another 4GB stick to upgrade it to 8GB (or some other combination of RAM capacity like 4x 2GB sticks).
https://linustechtips.com/topic/1063648-i-need-help/#findComment-12564647
Offer him 200, anything higher then that.. It's just not worth it.
If you're able too.. You could just buy some parts and build yourself one for about 500-600. That's actually a lot better. The money you would spend "upgrading" that $200 dollar PC wouldn't even be worth it.
https://linustechtips.com/topic/1063648-i-need-help/#findComment-12564663
I have purchased MANY of these systems and even built them to similar specs
When i purchase a computer with that era processor, ram, ssd ect its approx $100-150
With a GPU as a "Gaming Computer" I would sell for about $300-350 MAX
The i5-750 is a very weak CPU for gaming. Fortnite would be 40Fps on Medium with low draw distance fyi
https://linustechtips.com/topic/1063648-i-need-help/#findComment-12564664
3 hours ago, Squanchy said:
Really? Single-channel RAM and 2400Mhz for Ryzen? Also no point in that cooler at such a tight budget, the stock AMD one is adequate.
While I generally favor the RMx PSU as those are really good, a cheaper TXM works just fine.
PCPartPicker Part List
CPU: AMD - Ryzen 3 2200G 3.5 GHz Quad-Core Processor  ($79.99 @ Amazon)
Motherboard: ASRock - B450M PRO4 Micro ATX AM4 Motherboard  ($75.71 @ Amazon)
Memory: Patriot - Viper 4 8 GB (2 x 4 GB) DDR4-3000 Memory  ($45.98 @ Newegg)
Storage: Crucial - MX500 500 GB 2.5" Solid State Drive  ($66.89 @ OutletPC)
Video Card: Sapphire - Radeon RX 580 8 GB NITRO+ Video Card  ($209.99 @ Amazon)
Case: Fractal Design - Focus G (Black) ATX Mid Tower Case  ($49.83 @ Amazon)
Power Supply: Corsair - TXM Gold 550 W 80+ Gold Certified Semi-modular ATX Power Supply  ($69.99 @ Amazon)
Total: $598.38
Generated by PCPartPicker 2019-05-13 23:08 EDT-0400
Dropped the modularity of the PSU
Dual channel & high speed RAM
Much better GPU
500GB SSD for OS & storage instead of regular HDD.
CPU: AMD Ryzen 5 3600  Heatsink: ID-Cooling Frostflow X GPU: Zotac GTX 1060 Mini 6GB RAM: KLEVV Bolt 3600Mhz (2x8GB) Mobo: ASUS B550-F ROG Strix (Wifi)  Case: Fractal Design Meshify C PSU: Deepcool DQ-M-V2L
https://linustechtips.com/topic/1063648-i-need-help/#findComment-12564959
deleted
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/1063648-i-need-help/#findComment-12565309
23 hours ago, Spotty said:
i5 750 = $20 (eBay)
Used 1TB HDD = $10
RD 380 = $80 (eBay)
Case = $30
PSU = Worthless
So yeah, $200ish.
I got an i5 2400 and a 1060 3gb for that same price believe it or not. The 1060 may be slightly bottlenecking the processor but you can always make a processor upgrade in the future.
The best budget build is just getting a cheap optiplex and slapping a gpu into it.
Also, if you intend to get a cheap optiplex with an i5 2400 then an i5 2400 is the highest you can get since Dell made there own custom chipset which prevents you from upgrading anything other than a i5 2400. And they do that with alot of there motherboards that way your not just upgrading your system. Your buying new dell pc's so if you want to do a CPU upgrade you'll have to get a motherboard. But the CPU being bottlenecked or not, it's still pushing more frames than that system you listed. It's a great system for a CUSTOM build pc but if you just purely want best bang for your buck. Your best bet is an optiplex with a 1060 3gb ( which is what I got for the same price ). No question about it.
My Rig:
CPU: Intel i5 2500k 4 Cores, 4 Threads @ 4.5ghz ( asus uefi regulates BIOS and adjusts it, there is no manual option, so I can't get any higher than 4.5, but I theoretically should be able to get higher once I get a voltage "changeable" mobo
MOBO: Asus P8Z68 LE
RAM: Kingston HyperX Predator 2133mhz ddr3 2x8 16GB
GPU: GTX 980 TI 150+ core, 100-150 ( I forgot )+ mem ( OC )
HDD: 500GB 3D MLC Samsung SSD ( soon ) + 2tb 7200rpm Seagate Constellation ES.2 SAS / LSI MegaRaid MR Raid/SAS Controller
CASE: Phanteks P350X
OS: Windows 10 64-bit / Void Linux
PERIPHERALS: IBM Model M 1984, Logitech G703 Mouse, Logitech G502 Mouse, Philips SHP9500 w/ V-Moda Boom Pro hooked up to my Sony AMP ( forgot model name, to lazy to find out )
Laptop: Gateway P-7805u FX
CPU: 2.26GHz Intel Core 2 Duo P8400 2c/2t
RAM: 8GB DDR2 1066mhz sodimm
GPU: Nvidia GeForce 9800M GTS
HDD: 320GB 7200rpm hard drive 2.5"
SSD: Kingston A400 250GB SSD
SCREEN: Glossy 16:9 1440x900
OS: Windows XP SP3 / Ubuntu 19.04
PERIPHERALSLogitech G Pro
https://linustechtips.com/topic/1063648-i-need-help/#findComment-12567361
