Greetings my fellow computer enthusiasts,
I recently began my plans for my first home server. I am partly doing this to put into practice what I have been learning in my Computer Science Master program and partly doing it for fun. While I am confident on the software side of things I would like an nth opinion from those more experienced in hardware. Here is the link: https://pcpartpicker.com/list/kwQrNQ
Most of the time it will be a simple home media server but I will also be using it in personal data science projects in the future, hopefully, by then my ram will be past the 100GB mark
I wanted to find a high quality, but economicly priced power system around 400W but only found some in the 550W range which were still in stock. The current wattage is a bit low comparatively because I do plan on expanding and maxing out my drive capacity as well as adding ram.
I will be shucking those hard drives to drive the price down.
Is this design ok, should I make minor modifications or restart from scratch?
https://linustechtips.com/topic/1063582-first-home-server-project-hardware/
Can you go used? id look at something like a used dell r720 or r730 instead. you get much more bang for your buck, and there are some weird choises in your system.
looking at that system.
-why 2011-3, got lga 3647 if your going new
-why a400? Id get a better ssd, unless that is just a hypervisor boot, then get a drive to run vms on
-Im assuming your getting more than one stick of ram.
- I don't think that cooler will fit as the mobo is narrow and the cooler is normal
-why gt 710? The mobo has a igpu, and the 710 is way to slow to bother with for gpu computer.
Also power usage will be much lower than what the psu is rated for, thats just a max. This will probably idle at around 100w.
Perhaps consider going used hardware with something like this
Motherboard: https://www.ebay.com/itm/SUPERMICRO-X9DRI-F-Dual-Socket-XEON-LGA2011-Extended-ATX-Server-Motherboard/303029793059
CPU: https://www.ebay.com/itm/Intel-Xeon-E5-2695-V2-12-Core-2-4GHz-30MB-SR1BA-CPU-Processor/372648114890
Far more powerful CPU with 12C/24T @ 2.4Ghz vs 6C/12T @ 1.7Ghz. Great if you want to transcode or something like virtualisation or run simulations for learning.
It has 2 CPU slots so you can always expand by adding a second CPU later to double your cores & memory.
It uses DDR3 which is far cheaper for buying 128GB if you need that much for some reason.
Desktop: Ryzen9 5950X | ASUS ROG Crosshair VIII Hero (Wifi) | EVGA RTX 3080Ti FTW3 | 32GB (2x16GB) Corsair Dominator Platinum RGB Pro 3600Mhz | EKWB EK-AIO 360D-RGB | EKWB EK-Vardar RGB Fans | 1TB Samsung 980 Pro, 4TB Samsung 980 Pro | Corsair 5000D Airflow | Corsair HX850 Platinum PSU | Asus ROG 42" OLED PG42UQ + LG 32" 32GK850G Monitor | Roccat Vulcan TKL Pro Keyboard | Logitech G Pro X Superlight  | MicroLab Solo 7C Speakers | Audio-Technica ATH-M50xBT2 LE Headphones | TC-Helicon GoXLR | Audio-Technica AT2035 | LTT Desk Mat | XBOX-X Controller | Windows 11 Pro
Server: Fractal Design Define R6 | Ryzen 3950x | ASRock X570 Taichi | Asus RTX 4060 Dual OC | 64GB (4x16GB) Corsair Vengeance LPX 3000Mhz | Corsair RM850v2 PSU | Fractal S36 Triple AIO + 4 Additional Venturi 120mm Fans | 8 x 20TB Seagate Exos X22 | 4 x 16TB Seagate Exos X18 | 3 x 2TB Samsung 970 Evo Plus NVMe | LSI 9211-8i HBA
NAS: Innovision 4U 24-bay chassis (12GB MiniHD SGIO Backplane) | Intel Core i9-10980xe | EVGA X299 FTW-K | EVGA RTX 2080Ti Super FTW3 | 128GB (8x16GB) Corsair Vengeance LPX 3200Mhz | DEEPCOOL PN1000M PSU| Noctua NH-D12L Chromax Black | 16 x 16TB Seagate Exos X18 | 2 x 2TB Samsung 990 Pro | 2 x 2TB Intel U.2 P4510 | LSI 9305-24i HBA
Thanks!
Updated Server Setup:
Motherboard (not on PCPP yet): https://www.supermicro.com/products/motherboard/Xeon/C600/X9DRi-F.cfm
I think I still need some case fans but its super late and fans should be super easy. The power supply should be able to handle 6 additional HDD's and another 2-4 32GB memory sticks with the opitmal range of being 10-15% below the actual W.
Thoughts, critiques, angry rants?
4 hours ago, Context said:
Thanks!
Looking good, but keep in mind with FreeNAS you cannot add disks at a later time to a VDEV.
So with 2 disks like you have 2 x 8TB - you can set up a mirrored VDEV for 8TB (7.2TB usable) space, and then create a second VDEV later as you need more space, and add it to the ZPOOL to increase your total space.  But keep in mind that this setup you lose 50% space across the pool.
You might be better to just run 1 CPU to start with, and use the $$ to get an extra 8TB drive to create a RAIDZ1 to give you 16TB space with 3 disks....it's a better trade off for space vs redundancy vs cost.
That PSU should be fine. I'm running the same PSU with dual LGA1366 Xeons, 6 sticks of RAM, 7 fans (+2 coolers) and 15 drives
@Jarsky I don't plan on using FreeNas, I am familiar with Linux and will probably use Ubuntu. However, I am open to changing my mind. I want the freedom to change and update on a six month basis and from what it looks like your saying it is tougher to add drives with FreeNas. As mentioned before I am much more confident on the software side of things.
Sorry so many freenas threads recently, had it in my mind that you were wanting to use ZFS ?
MDADM has flexibility to move from a 2 disk RAID1 to RAID5, and to expand so all good.
At least it's not another unRAID thread ?
