Need info
Go to solution Solved by TVwazhere,
1 hour ago, koushik401 said:
i have circle eliminator x1 black with red led fan. can anyone tell me how to remove the front panel/acrylic glass front panel to change fans/ and is it possible to replace acrylic glass front panel with some kinda mess for more air.
sorry cant put any pics i dnt have mobile
A quick google search brought up this photo: (I just assume your fans are red instead of RGB)
Image result for circle eliminator x1
Most cases pull from the bottom to remove their front panels. I would imagine yours is similar, however there's no option that you can buy from the compant to replace the glass directly with mesh, so I would recommend three (3) 120mm fan mesh grills to cover the fans
https://linustechtips.com/topic/1063570-need-info/
Depends, either it comes off easily or its screwed or permanent connection meaning you can't do anything about it unless you want to break it.
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
https://linustechtips.com/topic/1063570-need-info/#findComment-12563699
yea im not sure about that and  without pic u cant tell much anyway unless u  have the same case ty tho :D
https://linustechtips.com/topic/1063570-need-info/#findComment-12563771
https://linustechtips.com/topic/1063570-need-info/#findComment-12563857
