Should you buy RTX 2060 water block from AliExpress?
Solved by SolarNova,
So the 2060 isnt really a good card to water cool.
BUT.
Aliexpress blocks, sure they are fine. So long as ur looking at Barrow and Bykski blocks. Just make damn sure your buyign the correct block for the model you have, most of the sellers there do make it clear you have to make sure ur buying the correct model.
I personally have a Barrow 1080ti block myself,
