Hello everyone!
So my question is- If I obtain a class E license what is the maximum load weight I can haul. And can I drive a 1 ton truck with a gooseneck? I keep seeing a number of GVWT allowing only up to 26000 lbs. But I’m getting confused with how they determine the GVWR. Btw, I’m in MO.
https://linustechtips.com/topic/1063142-class-e-license-help/
GVWR is the weight of the vehicle, passengers, load, etc. This number will be provided to you by the vehicle manufacturer. Subtract the weight of the truck from the GVWR, and that's how much it can carry.
For the trailer, it seems largely dependent upon whether it's private or commercial use. If you're just hauling your own junk, you should be good to go.
Disclaimer: I'm just some guy on the internet, what do I know?
Screwdriver specs: Long, pointy. Turns things. Some kind of metal.
Main rig:
i9-7900x | Asus X299-Prime | 4x8GB G-Skill TridentZ @3300MHz | Samsung 970 Evo 500GB | Intel 5400S 1TB | Corsair HX1200
unRAID server:
Xeon  E5-1630v4 |  Asus X99-E WS | 4x8GB G-Skill DDR4 @2400MHz | Samsung 960 EVO 250GB cache drive | 12TB spinning rust | Corsair RM750X
FreeNAS server:
AMD something-or-other | Asus prebuilt sadness | 8GB DDR3-1600 | 9TB magnetic storage | Potential fire threat
HTPC:
i7-4790 | GTX1650 | Dell Sadness | 12GB DDR3-1600 | Samsung 860 250GB | 1TB magnetic storage | James Loudspeaker SPL3 x2 | Corsair SF450
https://linustechtips.com/topic/1063142-class-e-license-help/#findComment-12561281
