2 hours ago, Emil_Loenneberg SE said:
Its a CSGO client called FACEIT
Usually reinstalling software fixes those. Re-download too. Software should make sure that all components it needs are installed already and add those that are missing during install process.
You can add some common .dll files manually if issue continue.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
I tried uninstallling and installing but it didnt work, but how do I add the .dll files manually?
Google the dll you need, download and run it. Though at this point contacting FACE-IT support might also be good thing. These things aren't common with commercial stuff, and usually issue is with something else. Like aggressive anti-virus.
I only have Windows Defender but could it be my PC Missing it? or just their program because it just happened randomly it was working fine before.
