Help: Need Cable/Adapters recommendation
Go to solution Solved by Glenwing,
You need a USB-C to DisplayPort adapter.
https://www.amazon.com/dp/B01EXKDRAC/?tag=linus21-20
Hello LTT community,
I have a MacBook Pro (late 2017), and I recently bought a Dell S2719DGF which supports 2560x1440 at 144hz. Unfortunately, my current setup is unable to support the 144hz. I am currently using HDMI to USB-C and I believe the issue is caused by the use of my USB-C to HDMI adapter (it's the Apple adapter).
If anyone could provide me with a link to an adapter or cable, it would be greatly appreciated as the product descriptions online are not all to helpful.
Thanks.
https://linustechtips.com/topic/1060386-help-need-cableadapters-recommendation/
Or a type C to HDMI 2.0 adapter.
HDMI 2.0 can do 1440p 144Hz.
