Hi, I have been plagued by this problem where I have low CPU, GPU usage thus resulting low fps. I was playing killing floor 2 and I realized that my GPU and CPU were barely making over 30% load and I am only getting 200FPS, I really want to achieve stable 240 because I am sure this computer can handle it and it will be a waste of a monitor too as it support 240hz and G-Sync. I uninstalled HPET but I cant find the option to disable it in the BIOS (even before uninstalling) Any help will be appreciated.
i7 8700k 5GHZ
2080TI Lightning Z
16GB Trident Z 3200
Aorus Gaming 7
RM850X
https://linustechtips.com/topic/1060186-low-cpu-gpu-and-fps/
4 minutes ago, Mr Magic Man said:
no it fluctuates it tries to stay at 240 but when there are a lot of enemies and explosions it goes down to like 180 or even 120 but the CPU and GPU usage is still really low
do you notice these drops or are they unnoticable? does benchmarks show more fps than what you are getting?
considering a 240hz freesync monitor would do the exact same these days, its sort of a waste, but running below 240hz is exactly why adaptive sync is a thing.
https://linustechtips.com/topic/1060186-low-cpu-gpu-and-fps/#findComment-12532015
they were VERY noticeable, I remember looking at one area it dropped down to 60(?) i was like was that even possible? and because I am very sensitive to frames I can tell if im on 190 or 220 or 240. Because muscle memory and how fast my mouse moves + the screen tearing.
https://linustechtips.com/topic/1060186-low-cpu-gpu-and-fps/#findComment-12532018
are u sure its screentearing. Adaptive sync prevents exactly that from happening.
i would recommend using DDU and reinstalling drivers. sadly ive got no more helpull advice.
https://linustechtips.com/topic/1060186-low-cpu-gpu-and-fps/#findComment-12532024
CPU might peak at 100% very briefly and hardware monitor doesnt pick it up because its too brief.
CPU: Ryzen 7 9800X3D Cooler: Noctua NH-D15 Black Mobo: Gigabyte X870E Aorus Pro GPU: Sapphire Nitro+ 9070 XT RAM: G.Skill 2x16GB @ 6400 MHz SSD: PNY XLR8 2TB PSU: Corsair RM1000x Case: Fractal Design North Monitor 1: Asus XG27AQWMG(280Hz) Monitor 2: Asus VG259QM (240Hz)
I usually edit my posts immediately after posting them, as I don't check for typos before pressing the shiny SUBMIT button.
Unraid Server
CPU: Ryzen 5 7600 Cooler: Noctua NH-U12S Mobo: Asus B650E-i RAM: Kingston Server Premier ECC 2x32GB (DDR5) SSD: Samsung 980 2x1TB HDD: Toshiba MG09 1x18TB; Toshiba MG08 2x16TB HDD Controller: LSI 9207-8i PSUCorsair SF750 Case: Node 304
https://linustechtips.com/topic/1060186-low-cpu-gpu-and-fps/#findComment-12532045
i dont know much about G-sync as I use AMD with Freesync but if they 2 are anything alike I dont think you will ever hit the 240 as the G-sync smooths FPS to remove tearing... in my own experiances my monitor is 144 and most of my games hover around or just under 100 FPS (apart from Guildwars 2 becasue the game engine is utter Gash) :s
https://linustechtips.com/topic/1060186-low-cpu-gpu-and-fps/#findComment-12537899
