Hi, this is my first thread here and i'm asking for my friend. He has this pc that we build but when we tried to start it, nothing happen. Only a light in mobo keeps blinking. We thought his psu is broken, but apparently that's not the issue.
I have this video of what happen when we start(im using evga 600br 80+ psu in the vid)
His build is:
Ryzen 5 2600
MSI Radeon rx570 8gb OC
Aorus b450 pro wifi
Corsair 2×8gb 2667mhz
Thermalake Smart rgb 750 watts(this is not the psu I used in the video)
Seagate Barracuda 2tb
I hope we find out whats wrong. Thank you
https://linustechtips.com/topic/1060091-custom-build-pc-not-working/
As Derrk suggested reseating Ram and GPU could fix the issue, if those don't work it wouldn't hurt to reseat the CPU, a very common issue with Ryzen installs is bent pins or improper CPU installation.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
I've dealt with this exact issue before out of the the two, one was bent CPU pins and the other was a dead motherboard.
Another possible fix is to reseat the whole motherboard as it may be getting shorted out by something (a screw possibly)
Current Desktop Build | 2200G | RX 580 4GB | 8GB RAM | CTRL | Logitech G Pro Wireless
Laptop | 2018 MBA 256/16GB | MX Master
Thank you for your answers. We tried unplugging all wires and we've also reseat the ram and gpu but all of those didn't work. What we didnt do is try checking out the cpu. We're kinda scared because we arent the ones who place the cpu in the mobo. His parts are also fairly new. Most of them is like less than a month old except for the gpu which I think already ~2 months old so we think we'll just bring it back to Memory Express though we dont know if they are going to fix it or replace it immediately since he dont have those store warranties.
Thank you again ! Atleast now we have a rough idea of what is wrong.
2 hours ago, Derrk said:
double check that all cables are connected, try reseating the gpu, reseating the memory.
One time when i built a friends pc i had a similar spinup before the system stopped, for whatever reason reseating the gpu fixed it
there is no ram look at the pic. dude you need to install ram
3 minutes ago, PC Budget Solutions said:
Video card is unplugged.
^ This.
The PCI-E 8-pin power connector that goes to the GPU is not connected.
There's TWO black Corsair LPX DRAM modules installed..
The motherboard has four DIMM slots.
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
Ohh now i see the ram
oh you are actually right so OP you need to plug the PSU into the GPU
1 hour ago, Neyne said:
Yes I connected already the gpu but still the same
i would try booting with only one stick of ram. try each dimm in each slot one at a time
like @zlolslavez said, there could be something shorting the motherboard. Check for loose screws, or if there's and extra standoff making contact with the back of the board
Ran into a similar issue troubleshooting my friend's PC last night.
Tried different RAM sticks and slots, different PSU, different GPU, clearing CMOS, etc.
It was a bent CPU socket pin right on the edge -- Intel platform.
Fingers crossed and bent the tiny pin back, praying to ALL the gods it would not break off...re-installed CPU and it's alive.
Since you mentioned the CPU was installed by the staff(s) at Memory Express, I would bring it back to them for some troubleshooting.
At least they would have extra parts lying around to try out.
AMD Ryzen 9000 Rig
AMD Ryzen 5000 Rig
  • AMD R7-5800X
