A few months ago, my hard drive died, I got a new one, reinstalled my programs and went on with my day.
Today, I opened Resolve, imported a file and tried to edit it. When I clicked play, the video played, but it was jumping very badly, like when Linux tried to play full compression 8K video in the recent video.
I rendered it out to see if that would fix the problem, but it was just the same result when I played the rendered file.
I can upload the rendered file to YouTube if you would like to see what I mean.
What are these for?
https://linustechtips.com/topic/1059628-davinchi-resolve-issues/
6 minutes ago, epikgamerwmp said:
i3-7100
GTX 1050
16Gb RAM
The strange thing it it had been fine when I have used the software in the past.
What res footage are you working with and in what format? Some are more system intensive then others. You should also open task manager and see if resolve is using your GPU more then 10%.
Also change your preview scale down and see if that helps. Even if the footage is rendered and you put it back in resolve it will still run slower then playing the footage in VLC or windows movie player.
Fine you want the PSU tier list? Have the PSU tier list: https://linustechtips.com/main/topic/1116640-psu-tier-list-40-rev-103/
Stille (Desktop)
Ryzen 9 3900XT@4.5Ghz - Cryorig H7 Ultimate - 16GB Vengeance LPX 3000Mhz- MSI RTX 3080 Ti Ventus 3x OC - SanDisk Plus 480GB - Crucial MX500 500GB - Intel 660P 1TB SSD - (2x) WD Red 2TB - EVGA G3 650w - Corsair 760T
Evoo Gaming 15"
i7-9750H - 16GB DDR4 - GTX 1660Ti - 480GB SSD M.2 - 1TB 2.5" BX500 SSD
VM + NAS Server (ProxMox 6.3)
1x Xeon E5-2690 v2  - 92GB ECC DDR3 - Quadro 4000 - Dell H310 HBA (Flashed with IT firmware) -500GB Crucial MX500 (Proxmox Host) Kingston 128GB SSD (FreeNAS dev/ID passthrough) - 8x4TB Toshiba N300 HDD
Toys: Ender 3 Pro, Oculus Rift CV1, Oculus Quest 2, about half a dozen raspberry Pis (2b to 4), Arduino Uno, Arduino Mega, Arduino nano (x3), Arduino nano pro, Atomic Pi.
mp4, 1080p30. I was watching the rendered footage in the win10 video player. tried reducing the preview scale to 720p. GPU not going thery high in usage.
What are these for?
bitrate?
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
