I am trying to diagnose any potential issue with a ryzen 5 2600. It stutters quite a lot in a whole lot of games. I am using the Ryzen balanced power profile most of the time. Sometimes I switch to performance. Not overclocked in any way. In HW monitor is see the voltages, but I can't make much sense of them. There is CPU VDD and under that #0 to #5 volt readings on ryzen balanced power plan. I think it jumps slightly if I set it to High Performance.  What should a healthy setup look like?
https://linustechtips.com/topic/1059560-how-do-you-read-cpu-voltages/
Voltages won't cause performance loss, just stability issues
Don't know about Ryzen but I think it should be around 1.2V at stock? not sure how much Auto Voltage pushes the voltages, it always applies way more voltage than what the processor needs, that also has nothing to do with performance though
VDD is the actual voltage supplied to the CPU
Quote or Tag people so they know that you've replied.
Just now, G9XFTW said:
In hopes of having the highest possible life span  (am I correct?) I'll try and run it in power saver mode when not gaming or doing productive stuff. It comes to 0.8V range in power saver, on idle.
anything below 1.35v won't damage your cpu, 1.4 MAY cause degradation in 2-3 years but still very unlikely to kill the cpu, you don't have to worry about power saver mode because the cpu isn't working anyway when you aren't doing anything.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
