So im looking for possible explanations for sudden frame drops in games, possible solutions in BIOS or something else that might solve these issues. Before i continue i will leave my specs:
Operating System
    Windows 10 Home 64-bit
CPU
    AMD FX-8350    13 °C
    Vishera 32nm Technology
RAM
    16.0GB Dual-Channel DDR3 @ 777MHz (11-11-11-28)
Motherboard
    ASRock 970 Extreme4 (CPUSocket)    32 °C
Graphics
    SAMSUNG (1920x1080@60Hz)
    Acer A221HQL (1920x1080@60Hz)
    2047MB NVIDIA GeForce GTX 1060 6GB (EVGA)    52 °C
Storage
    931GB Western Digital WDC WD10EZEX-08M2NA0 ATA Device (SATA )    24 °C
    931GB TOSHIBA DT01ACA100 ATA Device (SATA )    25 °C
    476GB SPCC Solid State Disk ATA Device (SATA (SSD))    33 °C
Optical Drives
    No optical disk drives detected
Audio
    Corsair VOID PRO USB Gaming Headset
Now ive been having problems while playing videos games or stream video games that has persisted through out many hardware changes. I have fresh installed windows to the SSD, got a boss cooling system. Did everythig other then replace my CPU, to whcih i have overclocked with no noticable change in the frame drops. During gaming, i will suddenly get CPU GHZ drops from 4.6 to 1.5. i used to believe it was thermal throttling due to watching how when the cpu hit 70c it would drop the performance down, but now it never gets higher then 50c and still has those issues. The thermal readings are in 45C so its not thermal throttling. For the life of me, i cant seem to figure out what is causing these drops, its not a program, its not a slow HDD as i use a SSD. Something is causing this and i will like to know what, and what can be done if anything. HELP PLEASE! :)
https://linustechtips.com/topic/1059445-sudden-frame-drops-inexplicable/
42 minutes ago, Plastic The Bag said:
During gaming, i will suddenly get CPU GHZ drops from 4.6 to 1.5. i used to believe it was thermal throttling.
It's throttling due to CPU/socket temps or VRM temps. You can never trust CPU temp readings with the FX processes unfortunately.
With saying it's dropping down to 1.5GHz when gaming indicates something is causing it to throttle for some unknown reason.
|King Of The Lost|
Project Dark: i7 7820x 5.1GHz | X299 Dark | Trident Z 32GB 3200MHz | GTX 1080Ti Hybrid | Corsair 760t | 1TB Samsung 860 Pro | EVGA Supernova G2 850w | H110i GTX
Lava: i9 12900k 5.1GHz (Undervolted to 1.26v)| MSI z690 Pro DDR4| Dominator Platnium 32GB 3800MHz| Power Color Red Devil RX 6950 XT| Seasonic Focus Platnium 850w| NZXT Kraken Z53
Unholy Rampage: i7 5930k 4.7GHz 4.4 Ring| X99
Rampage|Ripjaws IV 16GB 2800 CL13| GTX 1080 Strix(Custom XOC Signed BIOS) | Seasonic Focus Platinum 850w |H100i v2
Revenge of 775: Pentium 641 | Biostar TPower i45| Crucial Tracer 1066 DDR2 | GTX 580 Classified Ultra | EVGA 650 BQ | Noctua NH D14
So what can be done then? If its the VRM temps (Not familiar with that term)
VRM is due to the power delivery set up for the CPU that the motherboard has. I would get a fan blowing on them directly if you can and see if the same thing happens when gaming. If not then you have found the issue.
|King Of The Lost|
Alright man. First of all, thank you so dang much, it has literally been years of searching trying to find an answer to that question, and what i did, legit was take the rear fan thats beside the cpu, and tape some wax paper to curve downwards to the board, so that the air is first being somewhat insulated by the aftermarket cooler, and second so air is directly blowing onto the VRM module.
The result.... Freaking problem solved...
So thank you a million time man, seriously took years to get an answer for that.
Not a problem it's a common issue with AM3+ boards and pushing high voltage and clock speeds on some boards.
|King Of The Lost|
