Do you need it for your headsets? 5.1? http://www.amazon.co.uk/Express-Normalizer-Virtual-Speaker-Shifter/dp/B007RMMYFI/ref=sr_1_1?s=computers&ie=UTF8&qid=1390489132&sr=1-1&keywords=SOUND+CARD
Please don't get a SC. Get a Fiio e10. It would be cool to use with headphones. (assuming you're)
 [spoiler=CORMAC]CPU:Intel celeron 1.6ghz RAM:Kingston 400mhz 1.99gb MOBO:MSI G31TM-P21 GPU:Will add one later on! CASE:local ROUTER D-Link 2750U, D-LINK 2730U MOUSE:HP,DELL,ViP KEYBOARD: v7 SPEAKERS:Creative 245  MONITOR:AOC E970Sw HEADSET: Sony MDRx05s UPS:conex ups avr 500va PSU:idk OD:Samsung super writemaster STORAGE:80 gb seagate+ Seagate 1TB OS:Windows xp sp3 themed to Windows 7 + Linux |Rest all pc in my house will be updated from time-time
COMING SOON
https://linustechtips.com/topic/105933-sound-cards/#findComment-1416312
Most people here will tell you not to get one. At around £50, you're not going to improve your audio quality by much. I'd recommend maybe putting it towards a nicer pair of headphones/speakers/whatever else you might want. The only audio solution that really makes a big difference is an external DAC, but it will be hard to find a good one with your budget.
If you're set on a soundcard, then the one that @ANUPLUCIFERGAMER suggested is about as good as you'll be able to get.
https://linustechtips.com/topic/105933-sound-cards/#findComment-1416316
Im getting the Razer Adero's their 85 pounds and apparently good stero headphones, if you can reccomend the same quality headphones for cheaper im all up for it.
When I say quality, I mean headphones that aren't Razer. For £85 you could get a pair of SRH440, which will walk over most other headphones for the price.
https://linustechtips.com/topic/105933-sound-cards/#findComment-1416505
They look quite nice man, thanks i will chyeck them out, if you have any other takers let me know :)
https://linustechtips.com/topic/105933-sound-cards/#findComment-1416522
