Building a new computer with the CoolerMaster H500M. From what I've read, fans with a few, thick, blades are for pressure and thinner blades with more of them are for airflow. I'm going to mount the cpu aio to the front with the cases stock 200mm x2 fans. Then the radiator then 3x ??? fans inside. So, What style fans should I use in a pull configuration? Any suggestions on brands?
https://linustechtips.com/topic/1059232-which-style-case-fans/
https://linustechtips.com/topic/1059232-which-style-case-fans/#findComment-12523845
