Help!
Solved by BrinkGG,
Just now, fasauceome said:most of the time the pins are in the bottom right of the motherboard
-image-
share a pic of the board so we can see what you may have available
Here's the board from his computer. I can't find a picture of just the motherboard, but it looks like the front panel connectors are either just above the GPU or near the M.2 Drive.
@Pc-Rookie Do you mind taking a picture of the connector on your motherboard?
