$3500 to spend on these items alone.
I am going to create my own custom case and get all the watercooling and other stuff, im not worried about that right now.
I just wanna know what the title states, what should I get for mobo, cpu, ram, gpu for $3500?
Once I get this started and come to a conclusion, I will post a build log and off I go!
What do I want to use this computer for? Gaming and occasional rendering.
Please make it cost friendly, like no 3970k when the 3930k is basically just as good and $200 cheaper. Thanks a bunch!
Corsair 800D Case      NZXT Hue      NZXT Sentry-001LX     EVGA Gold Standard 850W PSU     Corsair Vengeance LED 32GB PC4 C15 DDR4 3000MHz     i5 7600k @ 4.2GHz     Gigabyte GA-Z270 ATX Gaming K3     8 Fans     Titan X     1.5TB Internal SSD
Corsair K70 RGB Keyboard     Logitech G602     Bose QC15 Headphones     c910 Logitech Webcam(used for microphone also)     (3) 27" LG Monitors     Bose Companion 2 Series III Speakers     Logitech Gamepad F310  Oculus Rift Tri-Cams
CLICK HERE TO SEE MY BUILD (not updated)
https://linustechtips.com/topic/10576-mobo-cpu-ram-gpu-help-me/
With that kind of coin to blow, I would actually suggest the Asrock extreme11 (X79 edition), it has an added PLX chip for full pcie3 16x support on 4 slots
onboard LSI raid, and I think a proper audio chip as well
get that, a 3930k, ram is practically irrelevant, dominator platinums look really cool. And like 4 GTX 680s, that would be completely ridiculous and I think it still falls within your budget, cut out one of the 680s or switch to 670s if it doesn't.
Ludicrous.
- Silverstone TJ08B-E - Gigabyte Z87M-D3H - i7 4770k @ 4.0GHZ 1.2v - 16gb Kingston HyperX Black 1600 - Gigabyte GTX 770 OC 4GB -
- Silverstone Fortress FT02 - MSI Z77 Mpower - i5 3570k @ 4.0GHZ 1.09v - 8gb Mushkin Blackline 1600 - MSI GTX 670 PE -
- Lenovo T430 (1600x900) - i5 3210m - 8GB DDR3 1333 - nVidia NVS5400M - 256GB mSATA OS - 320GB HDD-
https://linustechtips.com/topic/10576-mobo-cpu-ram-gpu-help-me/#findComment-115084
You can save some dosh.
Intel Core i7 3930k
ASUS ROG Rampage V Extreme Motherboard
Corsair Vengeance/Dominator GT/Platinum RAM: 16-32GB
2x GTX 680's or 2x 7970GHz GPU's
2x Titans are cool and great, but only useful if you have a 2560x1440/1600 monitor and Triple 1080p monitors.
CPU: Intel i7 4790k Motherboard: ASUS Maximus VII Formula RAM: Corsair Vengeance Pro 32GB 2400MHz: GPU: 2x EVGA GTX 780 Ti's with ACX cooling PSU: Corsair AX1200 Watt Gold SSD: SanDisk Extreme 120GB SSD (Operating System) SSD: Mushkin Chronos 240GB (Games) Sound card: Creative Sound Blaster ZxR HDD: Seagate 3TB External OS: Microsoft Windows 8.1 Mouse: Logitech G502 Gaming mouse Keyboard: Corsair Vengeance K60 MX Red switches Monitor: ASUS VG248QE 144Hz
https://linustechtips.com/topic/10576-mobo-cpu-ram-gpu-help-me/#findComment-115194
You really don't need to spend $3500 on these components depending on what you're using this comp for. Like for instance, if you're just gaming then a 3770k is plenty. Then grab an Asus maximus board, any 1600 c9 ram and you're good. For gpu grab 2 high vram gtx 670s or even a titan or 2 if you want to spend the lonely.
https://linustechtips.com/topic/10576-mobo-cpu-ram-gpu-help-me/#findComment-115343
What are you actually trying to do?
I think he's trying to build a computer, maybe, just a little bit xD
export PS1='\[\033[1;30m\]┌╼ \[\033[1;32m\]\u@\h\[\033[1;30m\] ╾╼ \[\033[0;34m\]\w\[\033[0;36m\]\n\[\033[1;30m\]└╼ \[\033[1;37m\]'
"All your threads are belong to /dev/null"
| 80's Terminal Keyboard Conversion | $5 Graphics Card Silence Mod Tutorial | 485KH/s R9 270X | The Smallest Ethernet Cable | Ass Pennies | My Screenfetch |
https://linustechtips.com/topic/10576-mobo-cpu-ram-gpu-help-me/#findComment-115700
lol - I'm more thinking along the lines of gaming, editing ect.
I know :P I think with such a large budget that it'll easily be able to do anything.
https://linustechtips.com/topic/10576-mobo-cpu-ram-gpu-help-me/#findComment-115708
With this kind of coin Id go with something crazy. Thinking Intel core i7 3930k, 2x 4GB 670s, Corsair AX 1200 PSU, Corsair Dominator platinum memory, etc. And for the mobo the little fans on the Asus and Asrock boards are kind of obnoxious so for a silent build, the MSI Big Bang Xpower looks sweet in any build, all blacked out with some gold. I would also recommend looking into a custom water cooling loop, with a cool looking reservoir. Another cool idea is a sweet SSD Raid Array, with like 2 ssd boot raid drives and 6 raid storage drives, with raid 10 for crazy speed and redundancy. You could probly also include sleeved cables to match the case and mobo, if you have the time to sleeve them or want to do pay someone to. For just gaming this is way overkill but with your budget you can totally get ballin components just for bragging rights and the "cannot has" factor.
https://linustechtips.com/topic/10576-mobo-cpu-ram-gpu-help-me/#findComment-116255
