Hey guys! Wanna invite you all to join my first proper build/Water cooling
First off, sorry for shitty grammar and bad use of the English language.
Currently the PC is my daily rig so updates will be happening on weekends and whenever time allows for it.
Basically, the rig is going to get a Thermal and build upgrade, Hardware wise there wont be happening any (planned anyway) upgrades.
Specs:
Ryzen 5 2600x
Asus ROG STRIX X370-I GAMING
16gb G.Skill RGB
Evga Geforce GTX 1070
Phanteks Enthoo Evolv Itx
Evga 550W
With the help of a friend we will be doing a hard tube build. (Renders of concept is below parts). Idea is to lower the ceiling of the case so that we can run soft tubing between everything up there and have hardtubing where visible so that everything will be looking sharp but still not too hard for us to do. At some point we might add a distro plate to the top instead but we need a CNC for that to happen first.
We want to create the "fake" Ceiling with some acrylic plate and paint.
We also want to do a custom back-plate for the GPU using acrylic and a laser cutter to do some engraving into the acrylic (Design not done yet)
All parts have been ordered and we are hoping to start the build within next week if possible.
Watercooling Parts:
Cuplex kryos NEXT with VISION AM4
EK-XRES 100 DDC
EK Water Blocks EK-FC GeForce GTX FE RGB - Nickel
2 x Noctua NF-P14s redux-1500
14 x Alphacool Eiszapfen fittings Nickel
6 x XSPC - 90° Adapter
6 x XSPC - ¼" BSPP (G1/4)
1 x Tubing - PVC - 13/10mm
1 x EKWB EK-CryoFuel Solid - Azure Blue
6 x XSPC - Bulkhead - G1/4 Black Chrome
1 x EKWB EK-AF Extender 6mm M-M G1/4
1 x EKWB EK-AF Extender Rotary M-M G1/4 - Nickel
1 x XSPC - G¼ Plug with 10k Sensor
1 x XSPC - 4 Way Fitting - G¼ - Chrome
52864520_2352512331658948_2799341786680524800_n.png?_nc_cat=104&_nc_ht=scontent-ams3-1.xx&oh=d4db13fadd21861dd489c7c567b08795&oe=5D3EA4A4
52832973_394337518045882_6124230683826061312_n.png?_nc_cat=109&_nc_ht=scontent-ams3-1.xx&oh=ec8afe0e74714dba863e5a401da6b90a&oe=5D4C30E4
51556202_351683305677354_928224556735266816_n.png?_nc_cat=110&_nc_ht=scontent-ams3-1.xx&oh=0e2d82898e46531808629c56b3e40524&oe=5D403F01
https://linustechtips.com/topic/1055024-first-proper-build/
typo on board name? Because Z370-I wont work with Ryzen
Desktop benching:
https://linustechtips.com/topic/1055024-first-proper-build/#findComment-12484907
  • 2 weeks later...
