Hello guys,
I build my first gamer pc yesterday, and now I can't her anything.
Can some one help me.
Here are maybe some important informations:
1) I downloaded Windows 10 Pro for free with the help of this tutorial: https://www.youtube.com/watch?v=bkafkI32Cs0
2) I am using this motherboard: https://www.msi.com/Motherboard/b450-gaming-pro-carbon-ac.html
3) I have tried 2 black inputs on left side at number 5 (over number 11).
Can some please help me. I wanna play today
https://linustechtips.com/topic/1054602-no-sound/
Check your sound options in the task bar and see what the default audio output device is set to. It's not uncommon for it to set the default to your monitor via HDMI when you install graphics drivers.
https://linustechtips.com/topic/1054602-no-sound/#findComment-12481053
3 minutes ago, NaPo97 said:
Hello guys,
Try the other inputs too
https://linustechtips.com/topic/1054602-no-sound/#findComment-12481054
Never mind, got the wrong idea of what you were trying to do  :D
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
https://linustechtips.com/topic/1054602-no-sound/#findComment-12481159
It works now! I simply tried to plug my headphones into the red cirkel at number 5. But the mic doesnt work, when I am playing CSGO, can you help me?
https://linustechtips.com/topic/1054602-no-sound/#findComment-12481320
... You don't need to post the same message 3 times...
Make sure the mic is plugged in to the microphone jack and that the microphone is set as the default option in windows sound settings.
Check to see if the game is set to use the mic you want to use, and if it is set to push to talk or voice detection.
https://linustechtips.com/topic/1054602-no-sound/#findComment-12481353
Hi
Try this
Windows --> Start
Type --> Manage audio device
Go to --> Recording Device
Make sure you have a microphone that is active
Go to properties -- left mouse click then right mouse click ,
If you look in the tabs you will  find the mic setting
There is also and option to listen to the mic
https://linustechtips.com/topic/1054602-no-sound/#findComment-12481396
26 minutes ago, Zmax said:
Hi
Try this
Windows --> Start
When I go to Manage Audio Device it says that my speakers is on. But it is not true. I dont have any speakers. When I press on the speakers I can see it is headphone because I have connected my headphone at the back panel to the place where speakers are supposed to be. Below the speakers there is a headphone-icon. When I press there it says the connection for the headphones are at the frontpanel. But the front panel doesnt work, when I connect my headphone the front panel. I dont know why.
https://linustechtips.com/topic/1054602-no-sound/#findComment-12481444
I have headphone also and you are right the icon for headphone is the speakers, but it works. I assumed that it's a windows thing.
As to your front panel , it's possible that the wiring is not done properly or disconnected, from MB.
Have you found the problem with your mic ?
https://linustechtips.com/topic/1054602-no-sound/#findComment-12484835
Yes I have :) Nono no wiring-problems. I plugged my headphone into some usb converter that came along with the headphone. And then the usb-converter to the computer. and it worked
https://linustechtips.com/topic/1054602-no-sound/#findComment-12496545
