i recently got ASUS RTX 2060 GPU and i get low FPS on it
My Specs
i7 -4770k
intel DH87MC
2 x 8GB RAM DDR3 Corsair Vengence
RTX 2060
Cooler Master 500watt PSU
500gb SSD
i had gtx 760 before and i used to get more fps with it.
i dont think its CPU bottleneck coz my cpu utilization is around 40-50 or max 60%
but my GPU utilization is 40% max and usually in 30% range. even in high end games like PUBG where as my GTX 760 used to have 99% gpu utilization
is my 500 watt psu not sufficient ( its 5 yrs old )
or it could be any other issue ?
plz help !
https://linustechtips.com/topic/1054525-low-gpu-utilization-rtx-2060/
I will say that if it was because of your PSU, you wouldn't get low utilization, your PC would just shut off in middle of the game when it pulls too much power.
Gaming - Ryzen 9800X3D | 64GB 6400mhz cl30 9070 XT
Homelab - many servers...constantly changing.
3970X/256GB - 5950X/128GB ECC - 5600G/96GB - 3400GE/16GB - 3400GE/16GB
Just now, Termi98oR said:
r u sure its not my PSU issue then ?
Yes. A dying PSU has absolutely zero correlation to GPU utilization.
14 minutes ago, Termi98oR said:
i get 150-200fps in RTX 2060 where as i used to get 200+ with my GTX 760
no i did not try ddu , my monitor is connected to my gpu.
Open HWMonitor let it run in the background while your playing the game. Post screenshot of CPU and GPU with all the stats showing.
This will go along way with troubleshooting.
Also are you OCing the GPU at all or is it stock?
https://www.cpuid.com/softwares/hwmonitor.html
Internet Connection
My Rig: AMD Ryzen 9 3900X @ 4.3Ghz | Asus Prime X470-Pro | Corsair Vengeance RGB Pro 32 GB (4 x 8GB) DDR-4 3000Mhz OC'd @ 3400Mhz 16-20-20-38 |
EVGA RTX 2070 8GB XC Gaming OC @ 2145Mhz Boosted/ 1925Mhz Memory | WD SN750 500GB M.2 NVME | Gigabye 240GB SSD |
XSPC EX 360mm | Corsair XC7 RGB CPU WB | EK-Vector RTX 2080 | Alphacool Eisbecher D5 150mm Plexi | XSPC Fittings | XSPC FLX Clear 7/16" ID, 5/8" OD |
Corsair LL120 x6 | Corsair RM750x White 2018 | Corsair Commander Pro | Corsair Obsidian 500D RGB SE | Corsair RGB LED Lighting PRO Expansion |
Corsair Strafe RGB MK.2 | Corsair Ironclaw RGB Wireless 18,000DPI | Acer 32" 4K 60Hz HDR600 Cert. ET322QK CBMIIPZX |
Passmark Score
3dmark Score
PC Parts Picker Link to Build
Network
Netgear LBR20 LTE Router | Verizon Unlimited Prepaid Hotspot Plan
HP 2530-48G-PoEP Switch
Rasberry Pi 4 Running Pihole
Linksys Velop 3 Mesh Wifi AP's
150-200fps on a GTX 760? Have you upgraded from like a 480p screen to a 1080p screen at the same time as swapping graphics cards?
i did not oc my gpu just using it at stock
