Vertical GPU Water Cooling?
Solved by SolarNova,
You can viably do it for sure.
Below is my recently refresh rig. I switched cases and ended up using a vertical GPU mount so i could fit my res to the rear of the case.
The mount is from Kaislin and has more adjustability than CM offering and allows for the use on the lowest most PCI-e slot for my sound card.
Vertical bracket and the GPU should not sag as the GPU itself should lock into the riser board at the bottom, and screw into the bracket at the top like normal ,and the bracket itself should attach with multiple screws to the rear of the case, resulting in a sturdy mount.
