Purpose built TR4 AIO's are somewhat limited.
I don't have firsthand experience with any of them, but I believe that CoolerMaster's ML360 is the best option available, but I wouldn't consider it all that impressive.
Enermax has a liqtech TR4 version as well, but it's known to have quality/manufacturing issues. Beyond that, I don't personally know of any other purpose-built models.
Support for standard AIO's will vary, they will work, but they won't cover the entirety of the IHS. spec sheets should have compatibility.
If you opt for a custom loop, EK makes TR blocks, but they're EOL, so you'll be buying used. Thermaltake, Koolance, XSPC, and Watercool (Heatkiller) make blocks as well. I don't know the status on any of these, however.
~Remember to quote posts to continue support on your thread~
-Don't be this kind of person-
CPU:  AMD Ryzen 7 5800x | RAM: 2x16GB Crucial Ripjaws Z | Cooling: XSPC/EK/Bitspower loop | MOBO: Gigabyte x570 Aorus Master | PSU: Seasonic Prime 750 Titanium
SSD: 250GB Samsung 980 PRO (OS) | 1TB Crucial MX500| 2TB Crucial P2 | Case: Phanteks Evolv X | GPU: EVGA GTX 1080 Ti FTW3 (with EK Block) | HDD: 1x Seagate Barracuda 2TB
I'm afraid this one isn't available for me... Other options?
Unfortunately, I don't know any more on the subject than what's above. I'm not on the Ryzen platform, much less TR, this is just all outsider information I know from being a tech enthusiast
If the ML360 isn't available, you can give the Enermax LiqTech TR4 360 a look, but as I said, it's very well established as having manufacturing and/or quality issues alongside long term stability as a result.
Outside of that, I believe you'll be looking for a standard cold plate AIO solution that supports TR4, but it will likely not be optimal, as it won't completely cover the IHS.
I understand. So how about kraken x62 or h115i?
This might give you a better indication on what to expect. As I said, my knowledge on cooling Threadripper with an AIO is entirely speculative as I have no first or second-hand knowledge on the matter.
The X62 is listed as compatible.
The H115i is listed as compatible with a separate bracket.
