Best Clip on Microphone?
Stevers108
Hi all!
I just have a question about a microphone. So basically, I am creating a trailer for a VR game that I am making for a school project and I plan on conducting interviews for the trailer (then putting them in the trailer). I'm looking for a budget clip-on microphone to record the audio while I conduct the interviews. I plan on using my Nikon D5500 camera to visually record the interview, and Adobe Audition to edit and clean up the audio. I don't have any experience when it comes to these microphones, so I thought I'd ask!
I was looking at these:
https://www.amazon.com/Professional-Omnidirectional-Microphone-Smartphones-Cancelling/dp/B073QP48RV/ref=sr_1_4?keywords=clip%2Bon%2Bmicrophone&qid=1555083082&s=musical-instruments&sr=1-4&th=1
https://www.amazon.com/dp/B075JHG28K/ref=sspa_dk_detail_9?psc=1&pd_rd_i=B075JHG28K&pd_rd_w=5zdSj&pf_rd_p=80559f3c-f83b-49c1-8a72-40f936e9df7a&pd_rd_wg=YqGuE&pf_rd_r=92229W939GCZ4170ZZVV&pd_rd_r=18363cc0-5d38-11e9-b1c8-45093f8a9dce
https://www.amazon.com/dp/B07KYQ9SCF/ref=psdc_196575011_t1_B01N9O7KWY
Thanks guys!
Steve
I bought this one recently on a recommendation from someone else: https://www.amazon.com/Professional-Microphone-Omnidirectional-Smartphones-Cancelling/dp/B016C4ZG74/ref=sr_1_4?keywords=lapel+mic&qid=1555084262&s=electronics&sr=1-4
But to be honest, I feel like most of them are likely going to be the same as long as there's a significant number of positive reviews.
They all do sound way below average in my opinion, if you're okay with that kind of sound quality then go for it, but otherwise I think it would be best to invest in a standard microphone with a separate pre-amp (Like an Audio Interface)
Quote or Tag people so they know that you've replied.
