Need help, anyone good at chemistry perhaps?
1 hour ago, TechHelp said:Sodium hydroxide strong base and nitric acid strong acid
And pH is a measure of acidity??
Both components are 'strong' so you don't have to worry about the ionisation potential of either - it would be different if you had something like acetic acid or ammonia for example.
pH is the -log (to the base 10) of the Hydrogen ion concentration
It's counterpart, pOH is the -log (to the base 10) of the Hydroxide ion concentration.
The sum of pH and pOH is 14 so once you know the concentration of one of the ions you can work out the rest.
You said you had worked out the concentrations - the acid will have been completely neutralised as the NaOH was in excess. Whatever your final NaOH concentration is also the OH concentration so you can calculate the pOH value then subtract it from 14 to get the pH. I got a pH of ~13.4.
