So I picked up a used gtx1070 strix from a friend of mine and I'm looking to build a computer with it. It will be used for graphic design, video editing, and gaming and I'd like to keep the rest of the build under $1000 not including peripherals. Some games that will be played on it include Monster Hunter World, Skyrim, Rocket League, Minecraft, and the borderlands games. Cant wait for borderlands 3.
I've worked up a parts list on pcpartpicker but I'm not sure what I need. I'm not trying to overclock for now but I would like the option to be there if possible. I will be having 2 monitors, resolution depending on the prices, at least 1920x1080. I live in the united states. I hope I'm not forgetting anything.
This is what I came up with, let me know how I did.
CPU: AMD - Ryzen 7 2700X 3.7 GHz 8-Core Processor  ($294.99 @ Amazon)
Motherboard: Asus - ROG STRIX B450-F GAMING ATX AM4 Motherboard  ($133.88 @ OutletPC)
Memory: Corsair - Vengeance LPX 16 GB (2 x 8 GB) DDR4-3000 Memory  ($104.99 @ Amazon)
Storage: Samsung - 860 Evo 500 GB 2.5" Solid State Drive  ($77.99 @ Amazon)
Video Card: Asus - GeForce GTX 1070 8 GB STRIX Video Card
Case: Phanteks - Enthoo Luxe Tempered Glass (Black) ATX Full Tower Case  ($169.99 @ Amazon)
Power Supply: EVGA - SuperNOVA G3 550 W 80+ Gold Certified Fully-Modular ATX Power Supply  ($87.98 @ OutletPC)
Optical Drive: Asus - BC-12B1ST/BLK/B/AS Blu-Ray Reader, DVD/CD Writer  ($62.88 @ OutletPC)
Total: $932.70
https://linustechtips.com/topic/1053587-first-pc-build/
4 minutes ago, quakeguy81 said:
I plugged that hardware into the Newegg Power Supply Calculator and they recommend at least a 582W power supply.  I wouldn't recommend anything less than 650W.
yeah, no. a 1070 rig won't eat more than 300w.
https://linustechtips.com/topic/1053587-first-pc-build/#findComment-12471498
CPU: AMD - Ryzen 7 2700 3.2 GHz 8-Core Processor  ($224.89 @ OutletPC) oc to make up the clock speed difference.
CPU Cooler: Scythe - FUMA Rev.B 79 CFM CPU Cooler  ($46.99 @ Amazon)
Motherboard: MSI - B450-A PRO ATX AM4 Motherboard  ($99.89 @ OutletPC) better than the B450-F.
Memory: GeIL - EVO SPEAR 16 GB (2 x 8 GB) DDR4-3000 Memory  ($75.98 @ Newegg)
Storage: Crucial - P1 1 TB M.2-2280 Solid State Drive  ($104.99 @ Adorama) much faster than the 860 evo.
Case: Phanteks - Enthoo Pro TG RGB ATX Full Tower Case  ($109.99 @ Amazon)
Power Supply: Corsair - RMx (2018) 550 W 80+ Gold Certified Fully-Modular ATX Power Supply  ($63.98 @ Newegg) much better than the G3.
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer  ($61.99 @ SuperBiiz)
Total: $788.70
Generated by PCPartPicker 2019-04-10 23:23 EDT-0400
https://linustechtips.com/topic/1053587-first-pc-build/#findComment-12471500
Per OP's original parts list
Component Estimated Wattage
Total: 279W
AMD - Ryzen 7 2700X 3.7 GHz 8-Core Processor 13W - 105W
Corsair - Vengeance LPX 16 GB (2 x 8 GB) DDR4-3000 Memory 14W
Samsung - 860 Evo 500 GB 2.5" Solid State Drive 2W - 10W
Asus - GeForce GTX 1070 8 GB STRIX Video Card 37W - 150W
This, brother, is what an almost 600W power draw system looks like
Total: 568W
AMD - Threadripper 2990WX 3 GHz 32-Core Processor 31W - 250W
G.Skill - Trident Z RGB 64 GB (4 x 16 GB) DDR4-3600 Memory 58W
Samsung - 850 EVO 4 TB 2.5" Solid State Drive 2W - 10W
Asus - GeForce RTX 2080 Ti 11 GB ROG Strix Gaming OC Video Card 62W - 250W
CPU: AMD Ryzen 5 3600  Heatsink: ID-Cooling Frostflow X GPU: Zotac GTX 1060 Mini 6GB RAM: KLEVV Bolt 3600Mhz (2x8GB) Mobo: ASUS B550-F ROG Strix (Wifi)  Case: Fractal Design Meshify C PSU: Deepcool DQ-M-V2L
https://linustechtips.com/topic/1053587-first-pc-build/#findComment-12471532
35 minutes ago, quakeguy81 said:
I plugged that hardware into the Newegg Power Supply Calculator and they recommend at least a 582W power supply.  I wouldn't recommend anything less than 650W.  I would recommend a cheap $20 DVD-RW over a Blu-Ray drive.  You really need commercial software Blu Ray player (PowerDVD) for it to play movies.
No more PSU calculator for u mister.
edit: also @ChrisBamerski I just got a used Blu ray drive for half that on eBay so I would consider used hardware if I were you
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1053587-first-pc-build/#findComment-12471537
2700 can be overclocked to slightly beat a stock 2700X, while maxed out 2700X wins the 2700 by a little. 2700 is much better value when it's this much cheaper
An overkill cooler to cool the CPU with low noise and handling upgrades
A board that is powerful enough to hold upgrades with more cores. If you'd rather buy a new board for potential new features (PCIe 4.0 for example, only useful for super fast storage that dont make much sense for their price) then get the MSI B450 Tomahawk for now, still much better than the Asus B450-F
Changed memory model to save money
QLC NVMe SSDs are faster with higher capacity for a similar price. Indeed less durability, but higher capacity tends to make up for it.
Changed the case to a mid tower one because no need for a more expensive full tower. Already holds a lot of 3.5" bay inside.
Dont really need 650w PSU (max power draw when overclocked is about 400w), but it is cheaper than smaller wattage units with modular cables and 80+ Gold cert.
Optical drive that can write BD as well, cost about the same as BD reader but no writer anyway
A bunch of case fans, all of them intake (except the 1 exhaust fan that comes with the case) helps reduce dust build up.
Total: 279W
Total: 568W
You didn't take factory boosting algorithm or higher power limit bios from the factory into account though. Agree that reading calculators are dumb.
Desktop benching:
https://linustechtips.com/topic/1053587-first-pc-build/#findComment-12471546
$80 in additional fans?  Get a better case then, wow.
$85 cooler?  It's a $225 AMD chip not a $350+ Intel chip.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1053587-first-pc-build/#findComment-12471550
sadly when you're using an enclosed case in the first place, more fans means better airflow. To not spend so much on fans and get similar airflow, go open air test bench.
you do pay for silence and upgradability
Desktop benching:
https://linustechtips.com/topic/1053587-first-pc-build/#findComment-12471566
Total: $788.70
Thanks for the suggestions, I just have a couple questions.
The ryzen 7 2700 and 2700x come with a CPU cooler (the wraith spire LED cooler). Is this a good cooler or would you still recommend getting the scythe cooler?
I've read that with some motherboards, if you use the m.2 slot the other SATA slots won't be usable. I can't find where it states this.
https://linustechtips.com/topic/1053587-first-pc-build/#findComment-12472961
motherboard spec page on the manufacturer website will state this. the stock cooler is decent but the fuma will help you keep temps down while overclocking.
https://linustechtips.com/topic/1053587-first-pc-build/#findComment-12472967
I chose the case because I was told the GPU was rather large so I would need a full size case. I was also under the assumption that a large case with more empty space would help keep the temp down.
I looked up open air cases. Should you be worried about the dust getting into the parts more compared to a closed case?
https://linustechtips.com/topic/1053587-first-pc-build/#findComment-12473036
You have a boatload of case options if fitment is your main concern.  Size isn't as important as airflow.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1053587-first-pc-build/#findComment-12473073
nowadays even small cases can hold long cards, PCPP has filtering for that.
If you dont mind cleaning it (say once every two to three months) or if you live somewhere with air so clean you can wash your clothes with the breeze and sunlight, you dont need to worry at all. If you have a fluffy pet though an open case is a no-no.
Desktop benching:
https://linustechtips.com/topic/1053587-first-pc-build/#findComment-12473326
I went through and changed some things and got my final build list. If anyone has any recommendations before I go buy everything id appreciate it.
CPU Cooler: Scythe - Mugen 5 Rev. B 51.17 CFM CPU Cooler  ($51.89 @ OutletPC)
Motherboard: MSI - B450 GAMING PRO CARBON AC ATX AM4 Motherboard  ($109.99)
Memory: Team - Vulcan 16 GB (2 x 8 GB) DDR4-3000 Memory  ($85.88 @ OutletPC)
Storage: Crucial - P1 1 TB M.2-2280 Solid State Drive  ($128.99 @ Amazon)
Video Card: Asus - GeForce GTX 1070 8 GB STRIX Video Card  (Purchased For $0.00)
Case: Corsair - 450D ATX Mid Tower Case  ($89.99 @ Newegg)
Power Supply: PowerSpec - 650 W 80+ Gold Certified Semi-Modular ATX Power Supply  ($64.99)
Optical Drive: Asus - DRW-24B1ST/BLK/B/AS DVD/CD Writer  ($19.89 @ OutletPC)
Other: ATECH FLASH TECHNOLOGY - PRO 88 ($39.95)
Total: $816.46
Generated by PCPartPicker 2019-04-15 22:41 EDT-0400
https://linustechtips.com/topic/1053587-first-pc-build/#findComment-12485555
Total: $816.46
https://pcpartpicker.com/product/v6gzK8/cooler-master-mwe-gold-750-w-80-gold-certified-fully-modular-atx-power-supply-mpy-7501-afaag-us
This power supply is A LOT better.
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/1053587-first-pc-build/#findComment-12485677
