I have two computers with almost identical setups.  Silverstone Grandia GD09B case, i5-3570k overclocked to 4.2 Ghz with a -0.45V offset, Cryorig m9 Plus cooler.  CPU A is on an Asrock Z75 Pro3 with a 50% LLC (options are 0, 50, or 100%), and CPU B is on an Asus P8Z77-V LX with a 25% LLC (options are greater).  Both boards are essentially operating under identical power and fan settings.
No matter how many times I reapply thermal grease or reseat the cooler, CPU A runs about 10C cooler than CPU B (Cores 1/2/3/4 under P95 = 56C/64C/60C/63C  and 69C/73C/76C/72C, respectively).  Is there a variable that I have overlooked involving the motherboards, or could there really just be that big of a difference in the silicon of the CPUs that one would run that much hotter than the other?
https://linustechtips.com/topic/1053409-10c-difference-between-same-cpu/
Have you used software to confirm the operating voltage?
Primary PC:
PSU tier list
How many watts do I need?
The Thermal paste between die and IHS could be a factor as well.
Internet Connection
My Rig: AMD Ryzen 9 3900X @ 4.3Ghz | Asus Prime X470-Pro | Corsair Vengeance RGB Pro 32 GB (4 x 8GB) DDR-4 3000Mhz OC'd @ 3400Mhz 16-20-20-38 |
EVGA RTX 2070 8GB XC Gaming OC @ 2145Mhz Boosted/ 1925Mhz Memory | WD SN750 500GB M.2 NVME | Gigabye 240GB SSD |
XSPC EX 360mm | Corsair XC7 RGB CPU WB | EK-Vector RTX 2080 | Alphacool Eisbecher D5 150mm Plexi | XSPC Fittings | XSPC FLX Clear 7/16" ID, 5/8" OD |
Corsair LL120 x6 | Corsair RM750x White 2018 | Corsair Commander Pro | Corsair Obsidian 500D RGB SE | Corsair RGB LED Lighting PRO Expansion |
Corsair Strafe RGB MK.2 | Corsair Ironclaw RGB Wireless 18,000DPI | Acer 32" 4K 60Hz HDR600 Cert. ET322QK CBMIIPZX |
Passmark Score
3dmark Score
PC Parts Picker Link to Build
Network
Netgear LBR20 LTE Router | Verizon Unlimited Prepaid Hotspot Plan
HP 2530-48G-PoEP Switch
Rasberry Pi 4 Running Pihole
Linksys Velop 3 Mesh Wifi AP's
I can't believe I overlooked the obvious.  Checking back on the screenshots I took of Core Temp the cooler CPU is reading as 67.2W under full load while the hotter one is reading as 79.9W under full load.  There has to be a voltage difference between the two as I imagine the amps have to be near identical.
I assumed the boards would just offset from the same stock voltage value.  Now I have to figure out why that Asus board is offsetting a higher voltage than the other and how to lower it.
No, not necessarily the voltages. Most boards have an option to remove the current limits. This way, the CPU can draw more current resulting obviously to higher temps.
You know, you could switch the CPUs between systems and verify that it's in deed the board and not the difference between CPUs. You might need to readjust your OC settings though.
Use the quote function when answering! Mark people directly if you want an answer from them!
If I can't track down the cause on the board I might do that... but I just got them reassembled all nice with the cables bound and tucked away... ?
Regardless, I am curious if it is plausible that it could just be a difference in the CPUs themselves.  A couple degrees difference wouldn't surprise me, but there is an 11.75C average core temperature difference here.
It is possible. A well overclockable chip with decent tim Vs bad overclocker and bad tim. Add in some variances due to boards and different VRMs...
Edit: just swap the chips. Then you'll know if it's the chips or the boards.
LLC setting might be a thing. That differs between the boards (check out some OC3D motherboard reviews to get experts  opinion). But like said, only thing to see for sure is to use same CPU on both mobos and do the testing. Like a real reviewer. I've watched enough of TTL's testing to know how much variation you can get from two boards, and even between two early BIOS versions.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
