I am building a pc for a friend and need some affirmation on some parts choices.
(All parts should be purchased in New Zealand)
This build is for creative and workstation style workloads - mostly video and music production with the adobe suite being his main applications. Specifically, the main apps being; Premiere/media encoder, davinci resolve, after effects, audition, illustrator and Avid media composer. As well as this, he will be doing casual modelling work in AutoDesk Maya and Blender however this workload is significantly less than the other. Also other music apps and photoshop will be used but they are not particularly demanding.
The budget for this build is approximately NZD$4000 which includes a high end, colour calibrated monitor.
Despite having access to an AMD Ryzen Threadripper 1950X at NZD $900, I have chosen to go with Intel i7-9900K (NZD $830) on the mainstream platform, purely due to a few forums saying that Ryzen has stuttering issues particularly in some adobe applications such as time line scrubbing in premiere. Also apparently Avid does not officially support Ryzen and has compatibility issues.
Should I be looking outside of the intel mainstream platform? Perhaps towards the HEDT (budget permitting). Can anyone offer any alternative perspectives to the Ryzen and Adobe/avid performance issues?
With the GPU; from research, I was under the impression that the higher you go, the diminishing returns become significant and he won’t be gaming so does not need huge graphics power but will likely need lots of VRAM. (Minimum 8GB). I currently have my eye on a stock standard RTX2070 due to them being better value at the lower end for these types of workloads but should I be looking at workstation style cards? Quadros for example. Or even AMD cards?
He will be keeping most of his files on external storage so does anyone have any suggestions regarding motherboards that have onboard thunderbolt (I believe this means limited to intel platforms? I may be corrected).
Build suggestions are welcome.
Here is the mock-up:
https://linustechtips.com/topic/1052894-new-workstation-build-help/
7 minutes ago, TSL said:
Corsair RAM isn't that great. I've had a lot of issues with mine, and know some people who had similar issues.
And you don't need that much wattage. And fyi, Gigabyte boards are meh.
Primary PC: - https://pcpartpicker.com/list/8G3tXv (Windows 10 Home)
HTPC: - https://pcpartpicker.com/list/KdBb4n (Windows 10 Home)
Server: Dell Precision T7500 - Dual Xeon X5660's, 44GB ECC DDR3, Dell Nvidia GTX 645 (Windows Server 2019 Standard)
*SLI Rig* - i7-920, MSI-X58 Platinum SLI, 12GB DDR3, Dual EVGA GTX 260 Core 216 in SLI - https://pcpartpicker.com/list/GHw6vW (Windows 7 Pro)
HP DC7900 - Core 2 Duo E8400, 4GB DDR2, Nvidia GeForce 8600 GT (Windows Vista)
Compaq Presario 5000 - Pentium 4 1.7Ghz, 1.7GB SDR, PowerColor Radeon 9600 Pro (Windows XP x86 Pro)
Compaq Presario 8772 - Pentium MMX 200Mhz, 48MB PC66, 6GB Quantum HDD, "8GB" HP SATA SSD adapted to IDE (Windows 98 SE)
Asus M32AD - Intel i3-4170, 8GB DDR3, 250GB Seagate 2.5" HDD (converting to SSD soon), EVGA GeForce GTS 250, OEM 350W PSU (Windows 10 Core)
*Haswell Tower* https://pcpartpicker.com/list/3vw6vW (Windows 10 Home)
*ITX Box* - https://pcpartpicker.com/list/r36s6R (Windows 10 Education)
Dell Dimension XPS B800 - Pentium 3 800Mhz, RDRAM
In progress projects:
*Skylake Tower* - Pentium G4400, Asus H110
*Trash Can* - AMD A4-6300
*GPU Test Bench*
*Pfsense router* - Pentium G3220, Asrock H97m Pro A4, 4GB DDR3
Use this for your PSU. - https://www.newegg.com/Product/Product.aspx?Item=9SIAFVF75E0931&Description=rmi&cm_re=rmi-_-17-139-138-_-Product
Also, do you really need a $300 Mobo? If you're not overclocking save some cash and get the Gigabyte pro wifiASUS's mobos dropped the ball this gen. (Gigabyte's VRMs are much, much better than most of the ASUS boards this gen).
PC - i7 12700K | EVGA FTW3 3090 | Corsair H150i | ASUS ROG Strix Z690-A | 32GB Corsair Vengance | Lian Li O11 Evo & EVGA 1k PSU
If my post solved your problem/answered your question, please consider marking it as "solved"
I heard Asus just has meh BIOS
*GPU Test Bench*
I prefer gigabyte over asus currently.
Just don't get a Gigabyte Ryzen board, I've heard horror stories about those.
*GPU Test Bench*
13 minutes ago, Infin1ty said:
might want to change that power supply, I chose the same one for a potential build and I was highly advised not to, apparently the g3 has problems
Based on JohnnyGURU reviews the G3’s seem to be excellent PSUs and my personal experience with EVGA power supplies is good and I haven’t heard otherwise for this line, but thanks for the feedback.
You can get away with 650W, you don't need to spend the extra.
You might even be able to do 550W, tbh
*GPU Test Bench*
EVGA G3's are in the budget teir on this list. You really wanna spend $200 on a PSU?
The G2's are phenomenal, G3's aren't.
You want the Radeon 7 for that instead because of 16GiB VRAM:
Those Videos might be very interesting to you.
As for the Rest: What is in use right now?
Is it possible to wait for the CPU? Because its said that on 27th May the 7nm Ryzen is released, wich might be a good choice for lower price.
The only thing we know is that the CPU presented earlier this year consumes roughly half the power of the 9900K.
"Hell is full of good meanings, but Heaven is full of good works"
I, too, am planning a workstation build. Mine is a virtualization build using Unraid, so ignore the random sound, ethernet, and extra GPU ?
The Ryzen 9 is using a direct conversion of the Taiwan prices per current leaks, and may change or be totally invalid.
PCPartPicker part list: https://pcpartpicker.com/list/gTtpTB
Price breakdown by merchant: https://pcpartpicker.com/list/gTtpTB/by_merchant/
CPU Cooler: be quiet! - Dark Rock Pro 4 50.5 CFM CPU Cooler  ($84.99 @ SuperBiiz)
Motherboard: Asus - ROG CROSSHAIR VI EXTREME EATX AM4 Motherboard  ($175.46 @ OutletPC)
Memory: G.Skill - Trident Z 32 GB (2 x 16 GB) DDR4-3200 Memory  ($320.98 @ Newegg)
Storage: Samsung - PM961 128 GB M.2-2280 Solid State Drive  (Purchased For $20.00)
Storage: Crucial - MX300 1.05 TB 2.5" Solid State Drive  (Purchased For $220.00)
Storage: Western Digital - Red 8 TB 3.5" 5400RPM Internal Hard Drive  (Purchased For $120.00)
Video Card: PowerColor - Radeon VII 16 GB Video Card  ($699.99 @ Amazon)
Case: Cooler Master - Cosmos ATX Full Tower Case  (Purchased For $20.00)
Power Supply: be quiet! - DARK POWER PRO 11 850 W 80+ Platinum Certified Semi-Modular ATX Power Supply  ($185.99 @ SuperBiiz)
Optical Drive: Asus - DRW-24B1ST/BLK/B/AS DVD/CD Writer  (Purchased For $62.00)
Optical Drive: Lite-On - iHOS104-06 Blu-Ray/DVD/CD Drive  (Purchased For $0.00)
Sound Card: Syba - SD-PEX63034 24-bit 48 kHz Sound Card  ($22.99 @ SuperBiiz)
Wired Network Adapter: Syba - SD-PEX24009 PCI-Express x1 1000 Mbit/s Network Adapter  ($11.89 @ OutletPC)
Case Fan: Noctua - NF-A14 industrialPPC-3000 PWM 158.5 CFM 140mm Fan  ($27.95 @ Amazon)
External Storage: Seagate - Backup Plus Slim 2 TB External Hard Drive  (Purchased For $20.00)
Other: Ryzen 9 3850X ($500.00)
Other: Generic DVD-ROM X2 (Purchased For $0.00)
Other: HD5450 (Purchased For $0.00)
Other: Optane Module (Purchased For $20.00)
Total: $2596.09
Generated by PCPartPicker 2019-04-08 19:00 EDT-0400
Brands I wholeheartedly reccomend (though do have flawed products): Apple, Razer, Corsair, Asus, Gigabyte, bequiet!, Noctua, Fractal, GSkill (RAM only)
Wall Of Fame (Informative people/People I like): @Glenwing @DrMacintosh @Schnoz @TempestCatto @LogicalDrm @Dan Castellaneta
Useful threads:
How To Make Your Own Cloud Storage
Guide to Display Cables/Adapters
PSU Tier List (Latest)-
Main PC: See spoiler tag
Laptop: 2020 iPad Pro 12.9" with Magic Keyboard
PCPartPicker Part List: https://pcpartpicker.com/list/gKh8zN
CPU: AMD Ryzen 9 3900X 3.8 GHz 12-Core OEM/Tray Processor  (Purchased For $419.99)
Motherboard: Asus ROG Crosshair VIII Formula ATX AM4 Motherboard  (Purchased For $356.99)
Memory: G.Skill Trident Z RGB 32 GB (2 x 16 GB) DDR4-3000 Memory  (Purchased For $130.00)
Storage: Kingston Predator 240 GB M.2-2280 NVME Solid State Drive  (Purchased For $40.00)
Storage: Crucial MX300 1.05 TB 2.5" Solid State Drive  (Purchased For $100.00)
Storage: Western Digital Red 8 TB 3.5" 5400RPM Internal Hard Drive  (Purchased For $180.00)
Video Card: Gigabyte GeForce RTX 2070 8 GB WINDFORCE Video Card  (Purchased For $370.00)
Case: Fractal Design Define R6 USB-C ATX Mid Tower Case  (Purchased For $100.00)
Power Supply: Corsair RMi 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For $120.00)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  (Purchased For $75.00)
Total: $1891.98
Generated by PCPartPicker 2020-04-02 19:59 EDT-0400
身のなわたしはる果てぞ  悲しわたしはかりけるわたしは
Thank you for the videos.
Currently he uses a laptop that is a few years old and was a huge limitation in his last project. We can’t wait for the new Ryzen CPU’s as he would like the PC ASAP, preferably within the next week. Also the rumours are for 7th of July for release and an announcement at computex. But they’re all rumours and that range of time frame is too great. I need to work with components that are available today, or within the next few at least.
The G3’s are not their budget tier. Check out johnnyguru.com for actually PSU reviews. After professional testing it performs incredibly well, 10/10 infact. The G2 is similar and over here in NZ they are the same price. So it makes no difference. I’m happy to stick with the G3. But thanks for the input.
I can get away with 650w you’re right, but Not 550w. With decent/modest OC the system will draw 500W. That’s far to much strain on the psu, even if it can handle it and will probably have no issues for years. I’ve chosen to go with 750w because of efficiency curves to do with power delivery. Power supplies reach their peak efficiency at around half load. If I see it better to go with an AMD gpu you can add 100-150w to that power draw number.
If one is sticking with stock settings a 550W psu would be fine for an i9-9900K. I'd want more capacity for overclocking, especially if one is going to loosen the power limits.
Asus has an excellent BIOS.
Other sites have expressed concerns with some of the power protections.
Thank you. One website does not make the final answer. Pick your answers from multiple sources.
