I currently have two systems one with an R5 1400 @3.7GHZ and an B350 MOBO, the other system has an i5 6500 and H170 MOBO. The GPU in the first system dies and the other system has a 960 4gb. I can sell either system and upgrade the other. I will sell the 960 for sure , however which CPU and mobo should I sell?
If I keep the i5 I'll upgrade to a Z170 mobo and overclock it.
And which GPU should I get such that I'll be able to play at 1080p 144hz at decent settings.
https://linustechtips.com/topic/1052549-need-help-for-a-build/
I would sell the i5 system since Ryzen offers the upgrade path to 6/8 cores for very cheap. GPU wise, I'd go for an RX 580 or if you've got a little more to spend a 1660 Ti
CPU: Core i9 12900K || CPU COOLER : Corsair H100i Pro XT || MOBO : ASUS Prime Z690 PLUS D4 || GPU: PowerColor RX 6800XT Red Dragon || RAM: 4x8GB Corsair Vengeance (3200) || SSDs: Samsung 970 Evo 250GB (Boot), Crucial P2 1TB, Crucial MX500 1TB (x2), Samsung 850 EVO 1TB || PSU: Corsair RM850 || CASE: Fractal Design Meshify C Mini || MONITOR: Acer Predator X34A (1440p 100hz), HP 27yh (1080p 60hz) || KEYBOARD: GameSir GK300 || MOUSE: Logitech G502 Hero || AUDIO: Bose QC35 II || CASE FANS : 2x Corsair ML140, 1x BeQuiet SilentWings 3 120 ||
LAPTOP: Dell XPS 15 7590
TABLET: iPad Pro
PHONE: Galaxy S9
She/they
https://linustechtips.com/topic/1052549-need-help-for-a-build/#findComment-12461505
What if I get a used 1070. It is about 200$ and it is faster than the 1660ti out of the box.
https://linustechtips.com/topic/1052549-need-help-for-a-build/#findComment-12461508
Both are perfectly valid options. If you're willing to buy used then I'd save up to $400 for a 1080 Ti
TABLET: iPad Pro
PHONE: Galaxy S9
She/they
https://linustechtips.com/topic/1052549-need-help-for-a-build/#findComment-12461527
