Full/Mid Tower Case recommendation
Go to solution Solved by metroid112,
Okay guys, thanks all of you for the suggestions. I started looking into some mid tower cases and one of the mentions was the Lian Li PC-O11.
I ended up buying the Lian Li PC-O11 AIR RGB which I found to be highly praised everywhere, a really nice aesthetic. I had to buy a new dust filter as the included one seems to have some issues, but the case was on an offer (being cheaper than the default AIR and it included 3 extra fans).
Hello guys I'm looking for case recommendations that are strictly under $200, Full Tower. My preferred places to buy is Amazon or Newegg, I plan to ship it internationally (Uruguay), so weight can change the price significantly, not that I don't mind paying a few extra bucks if the case is that good.
As for the other components:
  • I have no GPU decided yet, I currently have a 1060 that I'm planning to keep until a new AMD or Nvidia series comes out.
  • I plan to get a i9-9900k and cool it with a NZXT X72 Kraken or similar 360mm radiator. I think this is the biggest requirement the case should support a 360mm radiator that's close enough to the CPU since the hose length is limited.
  • For the motherboard I'm planning for a Gigabyte Aorus series, probably Pro or higher (They're all ATX sized except for the high tier one that I don't plan on getting).
  • I already got a 2x16Gb DDR4-3000MHz G.Skill Ripjaws kit I got on an offer at Newegg.
  • Currently own 2 regular SSDs and 2 regular HDDs.
I was deciding on getting something like a Phanteks Enthoo Pro or Corsair 750D Airflow edition, but I'm open to suggestions. I don't really like RGB that much but if the case is good, I'm fine with it (as long as I can turn the lights off lmao).
https://linustechtips.com/topic/1052264-fullmid-tower-case-recommendation/
I have a Corsair 780t and like it a lot. Good AF and easy to work on and cable manage.
I am a disabled Vet who had his hands crushed. Typing is not the easiest thing. So if I misspelled something please understand. Thank you.
Tantibus venit ades profunde tenebris ubi diabolus in ingluviem dentibus maxillas novaculam ubi angeli sulphuris accendit plorat.
 CPU Intel i7 9900k Motherboard ROG Maximus XI Code RAM 64gb DDR4 3000mhz Corsair Dominator GPU RTX 2080ti FE x 2 Case Corsair GRAPHITE 780T Storage 2 Western Digital Blue 4 TB HHDs, 1tb Western Digital SSD. Seagate Barracuda 2tb Hybrid drive, and  1 Western Digital M.2 1tb PSU Corsair HX 1200 Displays 1 Samsung U28D590 28in and 1 Samsung C49hg90DMN 49 Cooling Alphacool Eiswolf GPX Pro / Alphacool Eisbaer 240
Look at the Define R6, S2 and S2 Meshify,
Your point strikes home, that AIO cooler tubing can impact case options or placement.  I had to place my 360mm AIO on the top due to it having tubes too short for front mounting in R6.
Edit:  You may not need a full tower case.  Many mid-towers (and some smaller cases) can support a 360mm AIO.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
Yeah I just edited the thread to match the mid tower point, I guess big is not always better :P. Even as I post here I'm continually looking at reviews and case recommendations and there are many mid tower cases that could fit the bill too.
Mid towers like the roughly $100 Phanteks Enthoo Pro M TG, Coolermaster Mastercase H500 series, The above mentioned Fractal Design Cases, NZXT H700, Lian li PC-O11D just to name some of the best ;)
Tried and true classic with the Corsair 750D, and will have plenty of space in it to build.  If you want to go with something more current, I'd suggest looking into either the 500D or 678C.  Both are mid-towers which will give you a smaller overall footprint, but still have plenty of space inside.  Let me know if you have any questions about either case.
Looking for more details about a product, or experiencing technical issues?  Visit our support page below, and one of our Technical Support staff can help you out:
https://support.corsair.com/
There are a lot of cases out there, tried a few, but I always come back to Corsair, been using their cases since IIRC the mid 90's.
Now you're obligated to post a bit of the finished build :)
OnePlus Ecosystem:
3D Printing:
