So I have a 3570K and a 7970. I was experiencing crashes during BF4 (total system crashes, not just the game) although it may be a failure of the video driver. In any case, the first problem was that the CPU cooler was mounted badly. a motherboard upgrade solved this. Now my CPU doesn't go over 60C load and my GPU doesn't go over 70. it can't be temp throttling, so I am led to believe it is drivers.
can anyone point me towards the correct AMD driver? I started having this problem when I moved to an SSD and installed 13.11 clean. (previously I had 13.9) I'm going to try a clean BF4 install and hopefully that will help.
Daily Driver:
Case: Red Prodigy CPU: i5 3570K @ 4.3 GHZ GPU: Powercolor PCS+ 290x @1100 mhz MOBO: Asus P8Z77-I CPU Cooler: NZXT x40 RAM: 8GB 2133mhz AMD Gamer series Storage: A 1TB WD Blue, a 500GB WD Blue, a Samsung 840 EVO 250GB
https://linustechtips.com/topic/105205-driver-problems/
Before you try a clean install, make sure nothing else is crashing your PC.  Also make sure that you have the right drivers (right windows version ect)  Make sure you have the prerequisites that are listed on AMD's site (net framework ect)  Personally I'm using 13.12 and its working fine on my 7970.
Beneath this mask there is more than flesh. Beneath this mask there is an idea, Mr. Creedy, and ideas are bulletproof.
As I get older I get angrier more cynical, meaner. I feel some warning posts coming. I feel a ban coming. I was warned.
CPU-i5 2400 GPU-Sapphire Radeon HD 7970 OC Mobo-H67MA-D2H-B3 Ram-G.Skill Ripjaws 8gb 1333mhz Case-Fractal Define R4 PSU-Corsair CX750 Storage-Samsung EVO 250gb, 1tb WD Black,Hitachi 1tb Other stuff-Corsair K90, M90 Cooling-3x 140mm Fractal fans Sound-Sennheiser HD438 headphones
https://linustechtips.com/topic/105205-driver-problems/#findComment-1407264
