I had a issue with my PC losing power, I found spots of corrsion on the motherboard and the outside of the PSU. I ordered a new case, motherboard and PSU.
I have all the new bits, put it together and when I hit power it turns on for a few seconds then turns off, after a second it then turns back on the whole process repeats.
I noticed some red LEDs on the motherboard first the CPU light flash's red for 0.5-1 sec then the goes off, then DRAM light goes for about 2 sec then it goes off then the vga light goes on for a instant before the whole thing powers off.
I have 2 sticks of RAM I have tried running with both sticks individually in all slots.
I live in a small town and don't have anyone to borrow parts off for testing.
Really don't want to fork out for a new GPU or CPU without being fairly certain the old one is buggered.
Motherboard is H370 Aorus
Please help?! Anything else I could try?
https://linustechtips.com/topic/1051122-computer-wont-post-help/
Are the motherboard standoffs properly installed?
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
Have you remembered to install ALL necessary power connectors? Could sound like a component needs more power than it gets
Have you tried running without the GPU?
QUOTE ME IF YOU WANT A REPLY!
PC #1
Ryzen 7 3700x@4.4ghz (All core) | MSI X470 Gaming Pro Carbon | Crucial Ballistix 2x16gb (OC 3600mhz)
MSI GTX 1080 8gb | SoundBlaster ZXR | Corsair HX850
Samsung 960 256gb | Samsung 860 1gb | Samsung 850 500gb
HGST 4tb, HGST 2tb | Seagate 2tb | Seagate 2tb
Custom CPU/GPU water loop
PC #2
Ryzen 7 1700@3.8ghz (All core) | Aorus AX370 Gaming K5 | Vengeance LED 3200mhz 2x8gb
Sapphire R9 290x 4gb | Asus Xonar DS | Corsair RM650
Samsung 850 128gb | Intel 240gb | Seagate 2tb
Corsair H80iGT AIO
Laptop
Core i7 6700HQ | Samsung 2400mhz 2x8gb DDR4
GTX 1060M 3gb | FiiO E10k DAC
Samsung 950 256gb | Sandisk Ultra 2tb SSD
Similar issue happened with one of the PC at work, PC kept turning off and on. I just left it that way and it booted itself after a while. First I thought it was PSU issue but even after replacing..... it was doing that.
I have a EVGA 650w should be plenty of power.
Graphics card has all the slots are plugged in.  All the squares and rounded bits matched. (3+4)
CPU power has a 2+2 the first one the patterns match the 2nd one they don't, I looked on line and it said only the 1st is required the 2nd is for extreme overclocking.    I have tried just plugging in the first and tried having both plugged in, same result.
