I am creating a shadow box coffee table with an Xbox, PS2 and a gaming PC all skeletonized. I am having trouble sourcing flat flexible cables to replace the PS2's original ones in the length i need for my project. I have done a lot of searching and calling around and most places have minimum orders of 500 ea. i only need about 6 cables to complete this build. I have done all the wire splicing needed for the xbox but these FFCs are really keeping me from getting the PS2 to be functional. I could use any help possible and i really want to make this happen. Pictures included are first mock up and current progress.
https://linustechtips.com/topic/1050912-custom-flat-flexible-cables-need-help/
  • 1 month later...
On 4/2/2019 at 7:43 PM, ZUL8R said:
I am looking for the OEM cables in the FAT PS2 but at a specific length. James Where do you recommend i go to order these??
You would be best to measure the dimensions of the flat flex and see if you can purchase standard length replacements that are long enough for your application.
https://www.digikey.com/products/en/cable-assemblies/flat-flex-ribbon-jumper-cables/457
