dont need it as long as you have the 8pin
Desktop benching:
https://linustechtips.com/topic/1050522-cpu-power-supply-doubt/#findComment-12445124
you can blow up the motherboard before hitting the limit of the 8pin connector
Desktop benching:
https://linustechtips.com/topic/1050522-cpu-power-supply-doubt/#findComment-12445141
You need the CPU power cable to be plugged in or the PC won't be able to boot. Depending on your CPU, you might be able to OC with only a 4pin connector; but its better to use an 8pin connector if its available.
Primary PC: - https://pcpartpicker.com/list/8G3tXv (Windows 10 Home)
HTPC: - https://pcpartpicker.com/list/KdBb4n (Windows 10 Home)
Server: Dell Precision T7500 - Dual Xeon X5660's, 44GB ECC DDR3, Dell Nvidia GTX 645 (Windows Server 2019 Standard)
*SLI Rig* - i7-920, MSI-X58 Platinum SLI, 12GB DDR3, Dual EVGA GTX 260 Core 216 in SLI - https://pcpartpicker.com/list/GHw6vW (Windows 7 Pro)
HP DC7900 - Core 2 Duo E8400, 4GB DDR2, Nvidia GeForce 8600 GT (Windows Vista)
Compaq Presario 5000 - Pentium 4 1.7Ghz, 1.7GB SDR, PowerColor Radeon 9600 Pro (Windows XP x86 Pro)
Compaq Presario 8772 - Pentium MMX 200Mhz, 48MB PC66, 6GB Quantum HDD, "8GB" HP SATA SSD adapted to IDE (Windows 98 SE)
Asus M32AD - Intel i3-4170, 8GB DDR3, 250GB Seagate 2.5" HDD (converting to SSD soon), EVGA GeForce GTS 250, OEM 350W PSU (Windows 10 Core)
*Haswell Tower* https://pcpartpicker.com/list/3vw6vW (Windows 10 Home)
*ITX Box* - https://pcpartpicker.com/list/r36s6R (Windows 10 Education)
Dell Dimension XPS B800 - Pentium 3 800Mhz, RDRAM
In progress projects:
*Skylake Tower* - Pentium G4400, Asus H110
*Trash Can* - AMD A4-6300
*GPU Test Bench*
*Pfsense router* - Pentium G3220, Asrock H97m Pro A4, 4GB DDR3
https://linustechtips.com/topic/1050522-cpu-power-supply-doubt/#findComment-12445144
if the PSU is any good, yes
Desktop benching:
https://linustechtips.com/topic/1050522-cpu-power-supply-doubt/#findComment-12445184
Usually the 8 pin can be split into two 4 pin connectors for this purpose.
https://linustechtips.com/topic/1050522-cpu-power-supply-doubt/#findComment-12445307
