build advice
Go to solution Solved by LukeSavenije,
2 minutes ago, Muhammad2126 said:
could you recommend a good PSU under 100$ that is rated 80+ gold.
this list, tier a+ or S
I'm building this PC any advice would be helpful
Ryzen 7 2700
ARCTIC Freezer 34 Esports Duo
Asus Prime B450M-A/CSM
GTX 1080 (Used)
Seasonic Focus Plus 550 Gold (80+ gold)
Corsair ML140, 140mm Premium Magnetic Levitation Fan
Corsair Vengeance LPX 16GB (CMK16GX4M2B3000C15W)
Kingston A400 SSD 960GB
MX-4 4g 2019
https://linustechtips.com/topic/1048478-build-advice/
swap that out
meh
would swap it for a mx500, 860 evo, 660p or p1
https://linustechtips.com/topic/1048478-build-advice/#findComment-12428069
On 3/26/2019 at 8:45 PM, LukeSavenije said:
swap that out
meh
thanks Just swapped it for asus prime B450-plus as the vrms are better on it and that would allow some overclocking given decent airflow
550 watts is more than enough for 330 watt system
I cant buy any SSD that costs more than 125$ because in my country import fees are applied to any product that costs more than 140$ including shipping(15$ in this case)
https://linustechtips.com/topic/1048478-build-advice/#findComment-12431676
why keep it on asus? i mean, it isn't much better than you had...
no shit! it's the problem seasonic focus (plus and platinum included) has problems with high peak wattage cards, I'm preventing you from something big, believe me
https://linustechtips.com/topic/1048478-build-advice/#findComment-12431731
the B450-plus isn't that much better
550W is enough but that PSU has issues (any other units you can buy around that price?)
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/1048478-build-advice/#findComment-12431743
how about these:
msi B450 Tomahawk
EVGA Supernova 650 G3, 80 Plus Gold 650W
https://linustechtips.com/topic/1048478-build-advice/#findComment-12433872
5 minutes ago, Muhammad2126 said:
thank you very much you've been a big help
no problem
1 minute ago, Muhammad2126 said:
LukeSavenije by the way your profile picture is dizzying
it's going round
and round
and round
and round
and round
https://linustechtips.com/topic/1048478-build-advice/#findComment-12434035
