Gaming Build Help
56 minutes ago, Flowey said:I mean, if in a few years said friend wanted to overclock to add an extra year of gaming before becoming obsolete, I'm assuming going with a 650W is worth it? Also, that's a confusing profile pic, Kizuna + Aqua plus a banana? confusion.exe
Edit : It's a 1440p ultrawide
I know it's way over budget, but I can't cut more things off.
RTX 2080 is the main point, need that to get good frame rates on decent settings at 3440 x 1440 resolution.
650w PSU that's only a little more expensive than 550w one
Case fans to give good cooling
An SSD that's just big enough by QLC standards (if have doubt for durability, get larger capacity versions)
A motherboard that can support much more power hungry upgrades
A CPU that's already good enough for the resolution (since no need to hit super high frame rates)
That's not banana, that's Cirno's wings
