i want to upgrade my GPU and i need some help and advice. my current setup is:
Motherboard : Asus Z170-A
CPU : intel core i7-6700
GPU : MSI GTX 950 oc 2GB
Ram : G.skills Ripjaws 4series 16GB(2 x 8GB) DDR4 2666 MHz
PSU : Corsair VS650 80+
2 monitors at 1920x1080 60 Hz each
my budget is around 300 EU and was thinking for an MSI GTX 1660 Ti 6GB
https://linustechtips.com/topic/1048092-need-advice-for-gpu-upgrade/
What for? Games?
a RTX 2060 is what I'd go for personally, if not then the GTX 1660 as you can overclock it to be the same as the GTX 1660 Ti.
Personal Desktop":
Luna, the temporary Desktop:
Probably just save a little more and go with an rtx 2060. But if you wouldn’t need that kind of performance and/or can’t save anymore, a 1660 ti is fine. What’s your resolution and refresh rate?
i got dual monitor that run at 1920x1080 60 Hz each. The use its going for is casual gaming not hardcore but i play most new AAA games and i would like at least high if not higher graphics.
30 minutes ago, Oalei said:
go see the used market has to offer. like a 1070 ti/Vega 56 higher is better.
If you dont mind a Used GPU (either its for PC/Mining)
Higher the GPU need a better PSU along the way too
i am from greece and atm 1070 ti costs 450 EU+ new and about 300 used so for the same budget i would prefere a new GPU instead of a used one and vegas 56 are even more expensive almost double my budget
49 minutes ago, Princess Cadence said:
What for? Games?
yea for casual gaming but AAA titles 2060 is out of budget i would like that too
You can always save up so you make the best 'value' purchase.
The GTX 1660 Ti is not a value purchase when the cheapest GTX 1660 can match it with a 5 minutes overclock.
Personal Desktop":
Well that's unfortunate, I would likely do as @Princess Cadence said or just save more and get 2060
