Recently I've replace my Corsair VS450 80+ for my PC to a SuperFlower 80+ Silver 500W and also added a 480gb ssd for game storage. Since then, my pc will often freeze for about 6 seconds and then resume whatever is running on prior. The load and hdd led are both lit up when the freezing happens. What could be the cause of this and what can I do to prevent it from happening again?
My PC Specs:
CPU: Intel i5 8400
Cooler: Deepcool Gammaxx GT air cooler
Motherboard: MSI B360 Gaming Pro Carbon
RAM: Kingston HyperX Fury 8gb x 2 @ 2666
GPU: Zotac 1060 6gb AMP!
Storage: Kingston 240gb A1000 M.2, 480gb Kingston A400 SATA ssd, 1tb Seagate Barracuda 7200rpm
PSU: SuperFlower 80+ Silver 500w
Fans: 3x Deepcool RF120, 2x Tecware 140 and 1x Tecware 120
Case: Tecware Nexus ATX
Others: Deepcool 200 RGB Pro (2 rgb strips)
Peripherals: Tecware Phantom keyboard, Logitech G703, Steelseries Arctis 5 2019
Everything is running stock.
https://linustechtips.com/topic/1047372-power-usage-problem/
does using the old PSU remove the problem?
Desktop benching:
https://linustechtips.com/topic/1047372-power-usage-problem/#findComment-12418797
2 minutes ago, Ivan Inkoustek said:
It might be a hard drive related problem if only your prior tasks resume, maybye look if your Satas dont have some kind of dust on them. Or just try the old PSU again.
I rewired everything when I changed my PSU. My system is only about 4months old.
https://linustechtips.com/topic/1047372-power-usage-problem/#findComment-12418816
1 minute ago, EldrickLew said:
The reason I changed the PSU was actually because my PC was freezing frequently
5628dd6ecd9fa100f371_size30_w521_h534.jp
are you running a lot of background tasks?
Desktop benching:
https://linustechtips.com/topic/1047372-power-usage-problem/#findComment-12418824
18 minutes ago, EldrickLew said:
I can have chrome, discord and Spotify running and my PC will freeze suddenly
does Windows recognize all your memory?
Desktop benching:
https://linustechtips.com/topic/1047372-power-usage-problem/#findComment-12418853
OK, then we can rule out the PSU.
Guess you already have filled your new SSD with games? If not, disconnect the other drives and install windows on that drive to see if the problem continues?
You either have a bad install/drivers or some HW-issue, we need to pinpoint it.
Have you reset your BIOS/UEFI to defaults to rule out any bad OC/RAM-timings?
https://linustechtips.com/topic/1047372-power-usage-problem/#findComment-12419068
Ok, I'll start with doing a fresh install of windows and see if the problem still persists.
Hw wise will see if disconnecting the drives will help.
BIOS/UEFI has been reset and will try to see if the problem is still there
https://linustechtips.com/topic/1047372-power-usage-problem/#findComment-12419246
Is windows running on the HDD?
If so: have you checked the health of the HDD?
To me, this seems to be more a problem of the HDD than of the PSU.
Does the HDD make strange noises while the pc froze? (If yes, then try to immediately backup your data. I'm 99% sure that the problem is then caused by the (failing) HDD)
https://linustechtips.com/topic/1047372-power-usage-problem/#findComment-12419434
