My GTX1080 is stuck at 60 fps and i dont know why. xbox DVR is turned off, Nvidia control panel is set to use application settings for vsync. is my monitor capable of going over 60fps? no i dont believe so. i have used this tv before with another graphics card and have gotten fps readout of well over 100fps. strictly want my framerates unlocked that  way i can see how well my system is aging. just need vsync off for proper benchmarks
https://linustechtips.com/topic/1046544-stuck-at-60-fps/
Return to nVidia Settings, put to override applications and choose FastSync.
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/1046544-stuck-at-60-fps/#findComment-12411286
1 minute ago, Lockon1997 said:
either steams overlay or the benchmark in farcry 5 even 3D mark
yeah i suppose far cry 5 does test the card fully even if you have vsync enabled
PC: Alienware 15 R3  Cpu: 7700hq  GPu : 1070 OC   Display: 1080p IPS Gsync panel 60hz  Storage: 970 evo 250 gb / 970 evo plus 500gb
Audio: Sennheiser HD 6xx  DAC: Schiit Modi 3E Amp: Schiit Magni Heresy
https://linustechtips.com/topic/1046544-stuck-at-60-fps/#findComment-12411328
Just now, Lockon1997 said:
i just want to say i have had it read higher framerates with an older AMD card on the same tv and windows 10 so i know this has to work
Have you replaced the GPU's recently?
Did you DDU in safe mode before installing the video card?
Personal Desktop":
https://linustechtips.com/topic/1046544-stuck-at-60-fps/#findComment-12411332
has to work
Not technically, the card could be defective
are drivers updated? What are your specs?
✧・゚: *✧・゚:*  Quote for a reply  *:・゚✧*:・゚✧
✧・゚: *✧・゚:*   Ask for discord   *:・゚✧*:・゚✧
https://linustechtips.com/topic/1046544-stuck-at-60-fps/#findComment-12411335
um was never given an indication of the card being faulty as of yet. has ran perfectly fine except for not playing anything at 60fps. doesnt matter the game either. drivers are up to date as well.
https://linustechtips.com/topic/1046544-stuck-at-60-fps/#findComment-12411351
Did you check your game setting to make sure it isn’t capped in the game?
and specs are on my profile
Oh okay
https://linustechtips.com/topic/1046544-stuck-at-60-fps/#findComment-12411357
Oh okay
yes i did. in game settings are always maxed and vsync always turned off first thing i do before i play a game lol. im a graphics whore. i even bumped the in game limiter to 144hz
 just in case
https://linustechtips.com/topic/1046544-stuck-at-60-fps/#findComment-12411370
 just in case
Not sure, but check the nvidia control panel thing (I don’t have nvidia so I am not sure what it’s called lol)
anywho, there should be a setting for either frame caps or vsync. Try going through and checking again if you have already, when all else fails you could try a reinstall of windows or reset to default in the nvidia control panel
https://linustechtips.com/topic/1046544-stuck-at-60-fps/#findComment-12411383
been there done that brother. reinstall and re-default
https://linustechtips.com/topic/1046544-stuck-at-60-fps/#findComment-12411390
  • 1 month later...
