Hey guys my PC broke about a month ago the motherboard died, it was a Gigabyte Z77X-UD3H. I returned it to the store i bought it from and skip 3 weeks after I got a new motherboard a completely new one Z77X-UD5H which is really great. and I had about 100€ laying around I changed my PSU as well i got a corsair 80+ gold one whatever not really important right now. THIS saturday I sat down with my friends to build the PC we tried to turn in it on and there was NO video signal and then the PC shuts down itself and restarts and keep on doing this what should I do? before my old Motherboard broke the same thing happened and then the mobo died. Is the CPU dead? and oh yeah one more thing I unplugged the GPU to see if it caused the problem so I did that and plugged the HDMI into the motherboard and it kept doing the same thing I know it's not the GPU fault. Please help me It's has been over a month since I played on PC :(
https://linustechtips.com/topic/10460-help-pc-is-not-working/
Are you getting a POST? Are you able to get into BIOS at all? Unplug any drives/cd-rom and try with only a single stick of ram... You may also want to try and reset the BIOS as well, see if that kick starts it.
Forum Links - Community Standards, Privacy Policy, FAQ, Features Suggestions, Bug and Issues.
Folding/Boinc Info - Check out the Folding and Boinc Section, read the Folding Install thread and the Folding FAQ. Info on Boinc is here. Don't forget to join team 223518. Check out other users Folding Rigs for ideas. Don't forget to follow the @LTTCompute for updates and other random posts about the various teams.
Follow me on Twitter for updates @Whaler_99
https://linustechtips.com/topic/10460-help-pc-is-not-working/#findComment-112440
Nope I can't even get into BIOS all I see is a black screen and the PC making the turning on noises, so should I unplug my HDD and only leave the SSD which is my boot drive on?
https://linustechtips.com/topic/10460-help-pc-is-not-working/#findComment-112449
Use the motherboard speaker beeping noises to diagnose the problem. What kind of beep code did your computer make? Did you try unplugging all your hdd/ssd/cd drives like Whaler_99 said and seeing if you can get into the bios? Did you try doing a CMOS reset? Maybe try using one stick of ram?
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/10460-help-pc-is-not-working/#findComment-112457
I had a similar problem, look at the cpu socket pins and see if any are slightly bent
Main rig: i7 4790k, Cooler H55, EVGA GTX 980, Corsair Obsidian 250D, ASRock H97M-ITX/ac, G.Skill 8GB, 500GB 840 EVO, 1TB WD Black
Server:  HP DL380 G5 8x 300GB 10k Sata drives, 2x e5460 32GB Ram
NAS: Synology DS213 with 2 2TB WD Red Drives
https://linustechtips.com/topic/10460-help-pc-is-not-working/#findComment-112460
@mgsstar wait do you mean the Code that is displayed on the little motherboard display? it's says 15 if that's what you mean
https://linustechtips.com/topic/10460-help-pc-is-not-working/#findComment-112469
https://linustechtips.com/topic/10460-help-pc-is-not-working/#findComment-112633
Something similar happened a while ago when my mate built his with the same motherboard I have which is an MSI Z68A-G43 G3 and I think he didn't plug in the supplemental CPU power or something like that.
I highly doubt the CPU has failed, in 15 years+ of playing with computers I've only ever encounted a single CPU and that was an old Pentium 4 EE which the knob who owned it overclocked it to something like 5GHz and pretty much burnt it out.
Also any idea's what happened to it, I always thought Gigabyte make pretty much the best boards on the market?
DESKTOP - Motherboard - Gigabyte GA-Z77X-D3H Processor - Intel Core i5-2500K @ Stock 1.135v Cooling - Cooler Master Hyper TX3 RAM - Kingston Hyper-X Fury White 4x4GB DDR3-1866 Graphics Card - MSI GeForce GTX 780 Lightning PSU - Seasonic M12II EVO Edition 850w  HDD -  WD Caviar  Blue 500GB (Boot Drive)  /  WD Scorpio Black 750GB (Games Storage) / WD Green 2TB (Main Storage) Case - Cooler Master 335U Elite OS - Microsoft Windows 7 Ultimate
https://linustechtips.com/topic/10460-help-pc-is-not-working/#findComment-112672
It was my fault to be honest I accidently plugged the CPU fan in the wrong place and yeah it smelt like electronics burning shortly after lol
https://linustechtips.com/topic/10460-help-pc-is-not-working/#findComment-112673
ahh makes sense:)
https://linustechtips.com/topic/10460-help-pc-is-not-working/#findComment-112691
There has been a problem with some Gigabyte motherboards that if you have the reset switch from the case plugged into the reset pin on the motherboard, it will cause an infinite boot loop. Try unplugging it if you have it plugged in and turn it on.
https://linustechtips.com/topic/10460-help-pc-is-not-working/#findComment-112698
Assuming this works, should I re-plug the Reset cable again?
https://linustechtips.com/topic/10460-help-pc-is-not-working/#findComment-112716
I wouldn't. I have a Gigabyte UD4 Z68 board that has this issue, I keep it unplugged and I never use the reset button anyway.
https://linustechtips.com/topic/10460-help-pc-is-not-working/#findComment-112740
  • 8 years later...
