I'm planing to upgrade my PC by the end of the year but since not a whole lot will be released till then I'm seeing what I should upgrade first.
Current Build:
i5 6500 -> Alpfenföhn Brocken
Gigabyte B150-HD3P-CF
XFX 380X 4GB
Kingston HyperX 8GB 2133 Mhz
Those are the main things to upgrade because the rest is pretty okay.
So should I get a new GPU first or a higher tier CPU like a 6700 but I can't oc with that board so I'd love some input.
Thanks in advance ❤️
https://linustechtips.com/topic/1045850-pc-upgrade-advice/
Ryzen 3000 is launching late spring(ish) and rumors have navi scheduled for a mid-late summer launch. I'd lean more toward saying getting a graphics card now and see if ryzen 3000 is good when it launches. But I'm seeing the 6700k cheaper than the 6700, and it's stock performance is better, so if you plan to upgrade either go for the 6700k or the 7700k (mobo should support the 7700k with a bios update, if you go that way do the update while you have that 6500 or you'll regret everything) there's all of $40 difference between those CPUs.
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
https://linustechtips.com/topic/1045850-pc-upgrade-advice/#findComment-12405105
